Results 1 to 3 of 3
Thread: Prop balancer
    Prop balancer
    I'm looking for a prop ballancer. The old simple kind that the prop slides onto a rod and you set the rod on the cradle and the heavy blade rotates to the bottom. I dont need nothing fancy just to play around with my own stuff.
    What ya got?
    Simple cheap thing here might work? Might have to shorten the "cones"? https://www.ebay.com/itm/Motorcycle-...d/312729598607
    This one looks a bit better. But I can not fine out how WIDE it is. Meaning if a prop with rake will fit between the up rites
    Attached Thumbnails Attached Thumbnails Screenshot_20210305-201733_eBay.jpg   Screenshot_20210305-201744_eBay.jpg   Screenshot_20210305-201802_eBay.jpg
  1. GM 4.3L 262 vs. GM 4.3L 262 w/Balancer Shaft?
    By RrCoX22 in forum Technical Discussion
    Last Post: 09-17-2007, 08:48 PM
  2. OMC V8 harmonic balancer question????
    By Raceman in forum Technical Discussion
    Last Post: 12-10-2006, 07:16 AM
  3. Mercruiser 7.4L Harmonic Balancer ??
    By BigMackAttack in forum Technical Discussion
    Last Post: 09-11-2004, 12:39 PM
