Results 1 to 3 of 3
Thread: Prop balancer
03-04-2021, 03:57 PM #1
Prop balancer
I'm looking for a prop ballancer. The old simple kind that the prop slides onto a rod and you set the rod on the cradle and the heavy blade rotates to the bottom. I dont need nothing fancy just to play around with my own stuff.
What ya got?
03-04-2021, 04:28 PM #2
Simple cheap thing here might work? Might have to shorten the "cones"? https://www.ebay.com/itm/Motorcycle-...d/312729598607
03-05-2021, 09:22 PM #3
This one looks a bit better. But I can not fine out how WIDE it is. Meaning if a prop with rake will fit between the up rites
GM 4.3L 262 vs. GM 4.3L 262 w/Balancer Shaft?
By RrCoX22 in forum Technical DiscussionReplies: 5Last Post: 09-17-2007, 08:48 PM -
OMC V8 harmonic balancer question????
By Raceman in forum Technical DiscussionReplies: 6Last Post: 12-10-2006, 07:16 AM -
Mercruiser 7.4L Harmonic Balancer ??
By BigMackAttack in forum Technical DiscussionReplies: 6Last Post: 09-11-2004, 12:39 PM
