Results 1 to 6 of 6
Thread: Peak Volt Meter
03-03-2021, 04:55 PM #1Team Member
- Aug 2004
- Sault Ste Marie
- 27
Peak Volt Meter
Need some help here, pulled this 1970's or 80's Peak Volt Metre out of a box which hasn't seen daylight in decades. I honestly cannot remember which position the function knob should be selected to test stators. Have no manual and searching the internet has come up empty. Any suggestions where it needs to be set at?
03-03-2021, 07:51 PM #25000 RPM
- Feb 2013
- Northern Cal
- 190
- 18
- 37
Could "S" stand for "stator" by chance ? The + and - positions could be to switch polarity of the meter leads to verify connections get an upscale read on the meter before hitting with full voltage and damage the meter driving the meter "downscale "hard . With only 3 knob positions to check you should be able to decipher pretty quick how the meter works through the process of elimination checking stator cranking volts .
Start on the 500v scale watching for "Upscale " meter deflection and work your way down from there to make sure the meter is connected properly .Last edited by H2Okie; 03-03-2021 at 07:54 PM.
03-05-2021, 07:09 PM #3
"S" is for Sensor, not Stator.... for testing sensor coil output..... similar to the Stevens meter........ http://stevensinstrument.com/Instr.pdf%20CD-77.pdf
03-05-2021, 07:13 PM #4
You could call them and ask if they have any info on it anymore http://www.esitest.com/
03-05-2021, 09:09 PM #55000 RPM
- Feb 2013
- Northern Cal
- 190
- 18
- 37
Good find on those instructions .
03-06-2021, 09:53 AM #6Team Member
- Aug 2004
- Sault Ste Marie
- 27
Excellent Flabum1017! that's explains it all very clearly now, thank you for the instructions!
Mercury Tech: Oil, and volt meter issues.
By Newt in forum Technical DiscussionReplies: 6Last Post: 04-12-2017, 09:15 PM -
peak reading volt meter?
By baja200merk in forum Technical DiscussionReplies: 11Last Post: 06-28-2006, 09:36 AM -
Peak reading meter?
By clanton in forum Technical DiscussionReplies: 12Last Post: 08-15-2001, 04:52 AM -
Peak reading meter?
By clanton in forum Technical DiscussionReplies: 0Last Post: 08-07-2001, 09:50 PM -
DIY volt meter
By tombrown in forum General Boating DiscussionReplies: 2Last Post: 07-15-2001, 06:32 PM
