Results 1 to 2 of 2
    Sarasota, FL
    Thumbs up OMC Crossflow Lower mount question
    Hello Everyone,
    Hope everyone is well !!
    I read on an older post that using lower mounts from a 150GT, were a good upgrade to the stock mounts?? (regular 1983 Johnson 150).
    I hesitate to go full solids because of the extra vibration?? Seems I read the solids create quite a bit more vibration??
    I wasn't going to change the upper, is this a mistake. My stock one seems fine..
    Any thoughts, suggestions, would be appreciated....
    THX...AL
    '82 Checkmate Diplomat
    "83 Johnson 150
    best so far: 71mph
    '72 Duster340 4spd
    '72 Hemi Duster (under construction)
    Life is either a daring adventure or nothing!
    Nov 2001
    Niagara Falls, NY
    You can shim the mounts you have see this thread.
    https://www.screamandfly.com/showthr...TOR+MOUNT+SHIM
    Paul V.
    1987 Hydrostream Viper - 1973 V4 Evinrude 135 Crossflow "Shiny Motor"
  1. CCM Reads and blocks/solid upper mount crossflow
    By omcforever in forum Misc. Parts and Accessories
    Last Post: 12-21-2020, 11:55 PM
  2. Need solid upper mount for V4 crossflow
    By ChrisCarsonMarine in forum Misc. Parts and Accessories
    Last Post: 10-14-2016, 12:11 PM
  3. Mercury Tech: Question on Mercury Lower Units: 80' 2.4 200 lower swap to 2001 opti lower
    By NoRdO in forum Technical Discussion
    Last Post: 08-16-2016, 09:21 PM
  4. OMC Tech: Lower unit compatability question - Crossflow to Looper
    By Steve2ManyBoats in forum Technical Discussion
    Last Post: 01-04-2013, 06:44 AM
