Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
    Minneapolis MN
    Be sure to post pics I'll be doing similar :P
    You know I will.
  2. Likes LakeFever liked this post
  3. #17
    your over complicating it..
    make the throttle at the motor a pull cable for raising throttle and simply run 2 cables like for example bicycle brake cables/normal throttle cables for cars etc..
    (actual cables that are bendy/floppy, rather than the stiff single wired normal boat stuff.
    This would mean the cable for either one would simply go slack when the other one is being used . job done.
    But can only do this to the throttle not to the gear change...
  4. Likes LakeFever, tnelsmn liked this post
  5. #18
    Minneapolis MN
    Quote Originally Posted by mjw930 View Post
    I used this unit to give me mechanical hand and foot throttle. The hand throttle is a Livorsi and the foot throttle is the new SeaStar Pro Pedal.
    Attachment 483361
    https://marinepartssource.com/dual-s...8aAsjGEALw_wcB
    This is a diagram of the connections, I only used the throttle plate, didn’t need the shift plate.
    http://www.seastarsolutions.com/wp-c...a7-DS_Unit.pdf
    It works surprisingly well but make sure you use the extreme cables since the friction multiplies when you add the junction. And make sure to keep it lubricated so nothing binds.
    Any chance you have a picture of this rigged in your boat? The instructions with this thing are worthless, as I'm sure you know. Seems like clamps included went work with Gen 1 cables... I may have to build a few new clamps or something.
  1. think I'd rather work on my boat (s) than work today
    By Quinten in forum The Scream And Fly Lounge
    Last Post: 09-19-2013, 08:05 AM
  2. Got to give this guy credit! Great work! Metal Work!
    By The Big Al in forum Other Motorsports
    Last Post: 01-09-2008, 10:44 PM
  3. Will this work??
    By 1FASTLASER in forum Technical Discussion
    Last Post: 05-17-2006, 05:48 AM
  4. Engine Work in MS? Boatworks still doing engine work?
    By Dan Young in forum Technical Discussion
    Last Post: 09-19-2003, 04:45 AM
  5. will this work?
    By Dutch in forum Technical Discussion
    Last Post: 05-05-2003, 07:42 PM
