Results 1 to 15 of 18
Thread: Tell me why this won't work.
03-02-2021, 05:21 PM #1
I'm very near the end of my Hydrostream build. The boat won't be just a dedicated go fast boat, still plan lots of skiing, slow(ish) sunset cruises, etc. Heck I might even try to catch a few fish out of it. So I want to be able to use both a hand and foot throttle. I've considered just running two throttle cables and switching them at the motor, but that seems so clunky. I know L&S made a set up years ago, but those seem to be long gone. I think I can come up with a better way.
This is a rough video of this part in motion. It is drawn true to size to use Merc cables. The throttle moves 2.65" from what I've measured using the control box.
The smaller block on top would be connected to the foot throttle and also connected to the cable going to the engine. The bottom block would be connected to the hand throttle and effectively just move the foot throttle block along with it. The bottom(hand) block would attach to the cable end instead of the Merc pieces, using the set screw set up.
The top(foot) would attach using the Merc cable adaptor and a roll pin or something similar. This way the cable could stay put and allow the block to slide over it when using the hand control.
I hope this explanation makes sense. I may still toss this whole thing out and figure out a way to do everything at the foot throttle.
Going to have a friend 3D print this for me so I can see if it works. Then I'll probably have it machined out of aluminum.
Am I crazy? Open to criticism of what can be improved. Will be running a return spring at the engine, and probably a second inside this part on the foot throttle block.
P.S. The cad software is from Fusion 360 and its a free download.
scott reierson liked this post
03-02-2021, 05:59 PM #2
The only problem with that, is you will be fighting the foot pedal spring on the hand control..... That's a lot of spring tension to fight with your hand.
tnelsmn, phillnjack liked this post
03-02-2021, 06:05 PM #3
That is a concern at this point. Ive never felt how that feels so I'll have to see how bad it is. I suppose I could reverse the imputes so the hand is more the "master" then only run a spring in this unit and remove and springs tension on the hand control.
03-02-2021, 06:27 PM #4
I used this unit to give me mechanical hand and foot throttle. The hand throttle is a Livorsi and the foot throttle is the new SeaStar Pro Pedal.
https://marinepartssource.com/dual-s...8aAsjGEALw_wcB
This is a diagram of the connections, I only used the throttle plate, didn’t need the shift plate.
http://www.seastarsolutions.com/wp-c...a7-DS_Unit.pdf
It works surprisingly well but make sure you use the extreme cables since the friction multiplies when you add the junction. And make sure to keep it lubricated so nothing binds.Last edited by mjw930; 03-02-2021 at 06:30 PM.
Mark
LakeFever, scott reierson liked this post
03-02-2021, 06:30 PM #5"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
tnelsmn liked this post
03-02-2021, 06:44 PM #6Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3032
- 5318
Years ago I worked for a company rigging equipment we used different throttles at different locations using potentiometers and proportional solenoids.
03-02-2021, 07:06 PM #7
03-02-2021, 07:17 PM #8
Mico has 2 station hydraulic throttles... could mount 2nd cylinder to a hand control instead of a pedal?
(I have the L&S in my HST... not the best system, IMHO.)Last edited by David - WI; 03-03-2021 at 12:36 PM.
03-02-2021, 08:05 PM #9I used this unit to give me mechanical hand and foot throttle. The hand throttle is a Livorsi and the foot throttle is the new SeaStar Pro Pedal.
Well sh*t, didn't realize there was already something out there. Thats great and will save me a ton of time!
Thanks for the help!'78 Hydrostream Viking/'98 225 ProMax
03-02-2021, 08:40 PM #10Team Member
- Lake Coochiching, Ontario
- 7,769
- 276
- 487
- 1592
- 6 Post(s)
I had one of those Land and Sea throttles. It was too stiff to be much use for adjusting speed by hand. I’d use it to hold a throttle position and I could then remove my foot from the foot throttle. Useful in some circumstances, but Idon’t miss it
tnelsmn, David - WI liked this post
03-02-2021, 09:55 PM #11'78 Hydrostream Viking/'98 225 ProMax
03-03-2021, 08:34 AM #12
I went through the same thing and this is not a very elegant solution (aka it looks like ****) but it works surprisingly well. To be effective both controls need to have enough force to anchor the pivot when you are using the other control. Luckily there’s very little lever effect when you push back on the cable so the tension setting on the hand control and the return spring on the foot control will lock that portion of the lever. I’ve even gotten familiar enough with how it works to swing between control at cruising speed so switching doesn’t mean coming off throttle. I’m quite happy with the outcome, it just ain’t pretty.
Mark
03-03-2021, 08:41 AM #13
I'm not worried about how it looks, I'll hide it up inside the gunnel. So it will never be seen. Thanks for the tip!
03-03-2021, 12:32 PM #14
I have been thinking of using a short cable from the control box to the "OMC" side of the Hot Foot with a slotted attachment. With the control box at idle the Hot Foot acts as normal. If you advance the control it moves the Hot Foot it increase throttle. You can set a cruise speed and speed up with the Hot Foot, returnoing to your cruise speed. Thinking of this because the Hot Foot is a pain for pulling the kids on tubes or skis.
Had a Land and Sea unit years ago, it was stiff and would stick.18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
03-03-2021, 12:56 PM #15
think I'd rather work on my boat (s) than work today
By Quinten in forum The Scream And Fly LoungeReplies: 0Last Post: 09-19-2013, 08:05 AM -
Got to give this guy credit! Great work! Metal Work!
By The Big Al in forum Other MotorsportsReplies: 3Last Post: 01-09-2008, 10:44 PM -
Will this work??
By 1FASTLASER in forum Technical DiscussionReplies: 1Last Post: 05-17-2006, 05:48 AM -
Engine Work in MS? Boatworks still doing engine work?
By Dan Young in forum Technical DiscussionReplies: 0Last Post: 09-19-2003, 04:45 AM -
will this work?
By Dutch in forum Technical DiscussionReplies: 1Last Post: 05-05-2003, 07:42 PM
