Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
    Nov 2020
    New Zealand
Name:	cracked pinion.jpg
ID:	485850Ive pulled my case to bits and are going through it.
    Would it be typical to have a 43 44103-1 pinion matched with a 44 104/2 foreword gear ?
    The pinion is cracked on the top side boss and both have a radial or perpendicular wear line about 5/16ths in from the large end of each tooth.
    There are 2 cracks and one of them runs 1/16th down the side of the boss.
    These wont be going back in.
  2. #17
    Pekin, IL
    Quote Originally Posted by captblue99 View Post
    I need a prop shaft for 2:1 (2.0L) part # 44-94148
    Calculate shipping to Mobile, AL 36608 I can Venmo you the payment. Thank you, Sam
    I have several prop shafts but do not know where to find the part number on them or if it is on them anywhere.
    Is the lower a pre-load?
    Rock
    Team Junk
  3. #18
    Mobile, AL
    Hi Rock, Sam here, not sure i can help with identifying my prop shaft/lower unit, I'm a noob. But from what I have read... isn't a preload unit identified by having the pin sticking out of the top of the driveshaft? Problem is that its been over a year since I had it off and I just cant remember and i can't pull the lower right now to look. It's a 2:1 lower unit, stock 1994 2.0L Mariner 150 fishing motor s# 0B042790. Those were consumer motors so t's probably the weakest and cheapest of all available, LOL. Thank you, Sam
  4. #19
    Dec 2011
    S.C
    Do you still have the xr6 2:1 gear set ?
  5. #20
    Pekin, IL
    Yes I do.
    Rock
    Team Junk
  6. #21
    Dec 2011
    S.C
    I will take that gear set and a propshaft
  7. #22
    Nov 2014
    Cape Girardeau MO.
    Any 20in 2.5 drive shafts left with good water pump base seal area in good condition? Also if you have a pinion with 15 teeth on the gear side and 13 teeth on the inside and it looks good i will take that also. Thanks for looking. LMK.
  8. #23
    Jan 2012
    Kings Mountain NC
    Do you have a set of the 44103, 44104, and 44105 gears left? I sent you a PM. Thanks
  9. #24
    Pekin, IL
    Darknet I owe you an apology as I did not see this post. I will look today but don't think there were any drive shafts left. I'll check for the pinion. Sorry. Gmann I will check today.
    Rock
    Team Junk
  10. #25
    Pekin, IL
    I do have the pinion and sent you a pm.
    Rock
    Team Junk
  1. Lower unit woes.... some of the stuff I here!!!
    By Eagle One in forum Technical Discussion
    Last Post: 04-21-2012, 03:17 PM
  2. 3,0 lower unit versus 2,5 same stuff inside ?
    By ae23 in forum Technical Discussion
    Last Post: 02-24-2009, 05:22 PM
