Results 1 to 15 of 25
Thread: lower unit stuff
03-02-2021, 09:23 AM #1
lower unit stuff
Pretty much all Mercury. Some stuff very useable and some needs a little tlc to be useable. All prices plus the ride.
Drive shafts..................$20
Prop shafts....................$20
Loose dogs...................$5
Shift rods.....................$2
Prop shafts w/gears........$100
Prop shaft w/gears no pinion.....$75
Carriers........................$15
Reverse bearings............$5
Gears on left.................free very borderline but in a pinch
Pinions......................$10
Double row gears.........$20 gears good dogs not perfect but useable
Torquemaster case 3.0.....$200
XR6 case....................$200
All other cases............. $75
XR6 2:1 gear set with front bearing, shims, and pinion...... $200
I am not a lower unit guy and I do NOT know what most of these parts fit. I do NOT have any sportmaster, fat shaft, or associated parts. Cases all look to be useable. As with all my stuff you get it and don't like it you ship it back and I will refund money. Ya want it all make offer and save money. Give me your part # needed and I will see if it exists somewhere in the pile. Thanks
RockTeam Junk
03-02-2021, 09:26 AM #2
More
Team Junk
G-Train liked this post
03-03-2021, 12:38 AM #3
Got any coned cases in there? Iam need a few the drive shafts 20inch? If so ill take 3 driveshafts.. propshafts with gears a complete decent set? If so ill take that as well ..and any bearing carrier with rear drain in it? If so ill take that as well ..need 1.87 gears if possible..can call or text me after 6am 931 628 1485 thanks stephen
1979 hydrostream vector sold
2001 american offshore 26 twin 300 promaxs
2006 hydrostream comp vking horned 225 promax/
1986 23ft twin engine eliminator twin 225 promaxs SOLD
03-04-2021, 06:13 AM #4
Looking for 2 of the 20 inch drive shafts and 2 prop shafts
03-04-2021, 04:44 PM #5
No inline stuff ?
03-04-2021, 06:30 PM #6
He has an I-4 case on the far left and what looks like a I-6 case next to it. Not trying to steal the thread, but Tom Smyth message me with what you are looking for if rock does not have it...but contact rock first cause hes the one postin...
It also looks like he may have some CLE shafts or some CLE gears but I cant tell from the pics. I would take a good set of CLE gears that are any ratio as long as they all match. Let me know if you would mic the ID of a set for me to see if it would fit. Give me a call at 510-418-4911 if you still have some v6 gears and are willing to mic some parts.
Thank you, J Avery.8' Yellow Jacket - 25 hp Mariner
1990 Collins Mirage - 15" 260
25 hp Merc with dry side pipe
03-06-2021, 11:16 AM #7
Wish I new more about what fit what but alas I do not. Have one decent set 43-68548, 43-76250, 43-68447-1, and 52-34239 dog. The sets on prop shafts were 44103, 44105, and 44104. Other set on prop shaft 43-68548, 43-76250, and 43-68447. Pinions available are 43-44484, 2@43-75316, 43-78081, and 813688 60789c. Forward gears arer 813687 59074, 2@75314, 3@44104/2, 828168-1,78082, 77673. Reverse gears are 43-824987, 85462, 78908, 75315, 822824, and 76250.
Team Junk
03-07-2021, 10:48 PM #8
The reverse gear 822824, what pinion and fwd gear go with that? The 44104 2 fwd? I want that set if its complete and in good shape.
03-08-2021, 08:07 AM #9
I wish mother Merc had been more consistent with the part #s. Some sets are in sequence and others are not. I doubt the reverse gear mentioned goes with the forward gear mentioned cuz the forward gear mentioned is one of them in sequence. Complete set on prop shaft is 44103, 44104, and 44105. You mentioned measuring which I would be willing to do. 309-231-8019.
RockTeam Junk
RussF liked this post
03-08-2021, 11:23 AM #10
There are only 3 drive shafts left. After cleaning one has a compromised lower bearing surface and the other serious pitting around water pump area. Those are large pinion and are most likely useless. The small pinion shaft may be useable but barely.
RockTeam Junk
03-08-2021, 04:03 PM #11
Looking for a gear set that the fwd gear I.D. is 0.997 and the reverse gear/propshaft seal dia. is 1.242" The pinion to go with them is large, not small. If those gears are on one of your propshafts (the propshaft dia. at the seal would be 1.242") I will take the shaft, bearings and the 3 gears. Let me know if you have a set (any ratio) with those specs.
Thank you, J Avery
03-08-2021, 04:54 PM #12
Measured with caliper forward id right at 1.0 and seal area 1.19 so we are close. If you want to try I will ship it to you and if it is right and useable you pay $100 plus shipping. If it is not what you want you ship it back and pay nothing but the shipping back.
RockTeam Junk
03-08-2021, 07:52 PM #13
Ok, its only $100...I'll use it on something in the next decade regardless of what it is...I'll give you a call to figure the ship/pay details.
04-19-2021, 08:11 PM #14Junior Member
- Apr 2012
- Mobile, AL
I need a prop shaft for 2:1 (2.0L) part # 44-94148
Calculate shipping to Mobile, AL 36608 I can Venmo you the payment. Thank you, Sam
04-20-2021, 06:36 PM #15
thanks Rock I got my stuff a while back
Lower unit woes.... some of the stuff I here!!!
By Eagle One in forum Technical DiscussionReplies: 7Last Post: 04-21-2012, 03:17 PM -
3,0 lower unit versus 2,5 same stuff inside ?
By ae23 in forum Technical DiscussionReplies: 1Last Post: 02-24-2009, 05:22 PM
