Results 1 to 1 of 1
03-01-2021, 08:45 AM #15000 RPM
- Apr 2010
- Indian Lake Ohio
- 329
- 74
Help with temp gauge on 300 Promax
My boat had 260s on it originally and I replaced them with 1999 300 promax motors. The harness from the 260s had a separate tan wire coming out of it that connected to the temp sensor on the motor. When i hung the promaxs their is a tan wire near the harness that I connected. See attached pictures of how it is currently setup. My temp gauges are not working currently. Do I need to connect directly to the temp sensor on the head with the hardness wire or should I get another temp sensor for the other head like the link below to run the gauge? Thank You!
Temp Sensor Mercury 135-250HP 3.0L EFI 2000-2010 13536A13 | eBay
Autometer temp gage/stock mercury sender
By Go Time in forum Technical DiscussionReplies: 2Last Post: 06-02-2014, 08:42 AM -
250 EFi Temp Gage problems
By Superboat24 in forum Technical DiscussionReplies: 4Last Post: 04-05-2006, 12:13 PM -
Merc water temp gage p/n 79-816932a1 is NLA
By captcarb in forum Technical DiscussionReplies: 2Last Post: 05-12-2004, 04:40 PM
