Results 1 to 4 of 4
02-28-2021, 06:29 PM #15000 RPM
- Jun 2014
- United States
- 153
- 7
- 30
- 42
Forward gear bearing large or small
I have a later model 2.5 200hp gear case with the stamping from Mercury of 1647-9147-C4. How can I tell if this lower unit has a large or small forward bearing without disassembly?
03-01-2021, 01:24 AM #2Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
it is small bearing non ratcheting case
03-01-2021, 05:24 AM #35000 RPM
- Jun 2014
- United States
- 153
- 7
- 30
- 42
Thanks, Tex.
03-02-2021, 10:33 PM #45000 RPM
- Jun 2014
- United States
- 153
- 7
- 30
- 42
You were correct, Tex. It is no ratcheting and small bearing.
Mercury Tech: crank bearing size diffrence? large - small?
By roadkill636 in forum Technical DiscussionReplies: 2Last Post: 07-29-2014, 03:55 PM -
Large bearing 200 gear case ?
By Jim Gibbs in forum Technical DiscussionReplies: 3Last Post: 10-18-2010, 09:09 AM -
diffrence between large/small bearing 260
By alxb2003 in forum Technical DiscussionReplies: 3Last Post: 04-05-2008, 10:28 PM -
Forward Gear Bearing. HELP HELP HELP!
By Carter Powell in forum Technical DiscussionReplies: 0Last Post: 04-18-2005, 03:39 PM -
Hi-Po Cranks (2.5) - Difference between Large & Small bearing
By aalbert in forum Technical DiscussionReplies: 30Last Post: 05-19-2003, 10:06 PM
