Results 1 to 12 of 12
Thread: Spark Plugs
    Plainville, CT
    Spark Plugs
    Using NGK BU8H (surface gap, non-resister, OEM) and BUZ8H (surface gap, resister) in all of my outboards (mostly V6's). They seem to last forever and never need adjustment.
    Any advantage (or dis-advantage) expected in trying a gapped plug like B8HS or BPZ8HS-10?
    ...or is there an iridium equivalent that could be tried as well? I see there is a Denso IWF24 that matches physically, but not sure what to think of the heat range.
    Plainville, CT
    Looks like NGK BR8HIX is the iridium matchup.
    Florida Keys
    I use Br8hs-10’s because they run good, are easy to read, and cheap.
    '95 STV "The Blue Goose"
  4. Thanks Glastron1987 thanked for this post
    Likes Glastron1987, rgsauger, OnPad liked this post
    Apr 2007
    Big Pine Key, Fl
    Quote Originally Posted by Glastron1987 View Post
    Do not spend the money for the iridium,The plugs that mach 351 posted,ngk br8hs 10s are the best in a carb or EFI 2.5 200.We have used these plugs in everday motors or full on race motors....P,S..I use the BR8HIX iridium in my V6 pro drag engine??????
  6. Thanks Glastron1987 thanked for this post
    Likes Glastron1987, David - WI, OnPad liked this post
    Plainville, CT
    Thanks. BR8HS-10's do look like an economical choice and they are resistor as well. Maybe I'll given them a try.
    Plainville, CT
    So I tried the BR8SH-10 in place of the BUZ8H's I have been using for years in my XR4. They seemed to run fine except at low speed they rean rougher. I suspect they only needed to be run a little leaner at low speed. So, I was planning to make a minor low speed adjustment, but then remember that my particular carbs have jets even for low speed. So, I went back to the BUZ8H's, I don't want to mess with the jets. At least I gave it a try.
  9. Thanks cdubya thanked for this post
    The -10 means that they come gapped @ 1.0 mm. Which is .03937 .. just call it .040
    There is no reason to run that wide of a gap ... especially with a low output ignition.
    Try closing them down to .025 - .030 .. it will quit shootin ducks down low ..
  11. Thanks Glastron1987 thanked for this post
    Likes OnPad, Glastron1987 liked this post
  12. #8
    Plainville, CT
    Yeah I'll try that after getting a good gauge
  13. #9
    Jul 2023
    Calgary, AB
    I take it the br8hs-10's are suitable for all merc v6's?
    no clearance issues on a 2.0 l?
    shreveport,la
    Quote Originally Posted by strauss18 View Post
    They’re fine for that
    Erik Kiser
    Jul 2023
    Calgary, AB
    Minty thanks. Surface gap plugs are strange to me. Wouldn’t mind trying to decipher a normal plug while tuning
  16. #12
    An oldie ... but goodie
    https://www.strappe.com/plugs.html
  1. Spark plugs
    By bobkyle2 in forum Technical Discussion
    Last Post: 10-13-2010, 11:01 PM
  2. Spark plugs
    By JJB in forum Technical Discussion
    Last Post: 04-04-2006, 10:07 PM
  3. spark plugs in a 2.5 which ones best !!
    By triple x in forum General Boating Discussion
    Last Post: 03-26-2003, 01:16 PM
  4. Spark Plugs
    By JoeS in forum General Boating Discussion
    Last Post: 12-12-2002, 05:25 PM
