Results 1 to 3 of 3
    Akron OH
    Trim repair suggestions
    I have an 84 200 Merc with the old single ram trim. Where would be the best place to get a repair kit for the trim cylinder, I believe the part# is 79879A1. It slowly leaks down and I believe it is the cylinder. Also, starting to see a little smoke coming from the top of the trim motor. I had it apart and all looks fine, I cleaned the commutator and put back together but not sure of the armature condition. Should I consider another trip pump like a used Mercrusier for a little faster trim and maybe more available parts? Not racing just want it to work good. I seen parts on eBay but just looking for suggestions...
    Feb 2011
    HUDSON, FLORIDA
    I HAVE the same deal, my motor sounds horrible but works just fine. those old pumps use sae 30 oil. fyi. do you any visible oil, after it leaks down?
  1. Need suggestions on how to re-route power trim hoses
    By tripower in forum Technical Discussion
    Last Post: 04-30-2019, 07:01 AM
  2. Beaking Free at More Than 1/4 Trim. New Prop? Suggestions?
    By Capnmoench in forum Technical Discussion
    Last Post: 06-11-2018, 11:59 PM
  3. Mercury Tech: Power Trim Problems...Any Suggestions?
    By imtwink in forum Technical Discussion
    Last Post: 03-29-2009, 12:53 AM
  4. Trim Cylinder Repair
    By G. E. JOHNSON in forum General Boating Discussion
    Last Post: 09-21-2008, 11:26 AM
  5. Power Trim Repair?
    By agood1 in forum Technical Discussion
    Last Post: 07-19-2007, 10:10 AM
