Results 1 to 3 of 3
Thread: Trim repair suggestions
02-26-2021, 04:09 PM #1
I have an 84 200 Merc with the old single ram trim. Where would be the best place to get a repair kit for the trim cylinder, I believe the part# is 79879A1. It slowly leaks down and I believe it is the cylinder. Also, starting to see a little smoke coming from the top of the trim motor. I had it apart and all looks fine, I cleaned the commutator and put back together but not sure of the armature condition. Should I consider another trip pump like a used Mercrusier for a little faster trim and maybe more available parts? Not racing just want it to work good. I seen parts on eBay but just looking for suggestions...
02-26-2021, 04:51 PM #26000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 431
- 64
- 434
- 452
I HAVE the same deal, my motor sounds horrible but works just fine. those old pumps use sae 30 oil. fyi. do you any visible oil, after it leaks down?
02-26-2021, 05:18 PM #3
$110 for that kit: http://www.marineengine.com/newparts...um=MER79879A+1
Need suggestions on how to re-route power trim hoses
By tripower in forum Technical DiscussionReplies: 1Last Post: 04-30-2019, 07:01 AM -
Beaking Free at More Than 1/4 Trim. New Prop? Suggestions?
By Capnmoench in forum Technical DiscussionReplies: 24Last Post: 06-11-2018, 11:59 PM -
Mercury Tech: Power Trim Problems...Any Suggestions?
By imtwink in forum Technical DiscussionReplies: 3Last Post: 03-29-2009, 12:53 AM -
Trim Cylinder Repair
By G. E. JOHNSON in forum General Boating DiscussionReplies: 0Last Post: 09-21-2008, 11:26 AM -
Power Trim Repair?
By agood1 in forum Technical DiscussionReplies: 2Last Post: 07-19-2007, 10:10 AM
