Results 1 to 7 of 7
02-26-2021, 09:18 AM #1
CCM intake stuffers for 2.4 200 carb mota
Putting this thing back together. already have the CCM reeds (nice) and wondering about the stuffers. Front half is not cut.
Would I see a difference with vs without? Also how about 1" spacer? Is that for top end or torque? Lastly, can you use stuffer and spacer?1990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
02-26-2021, 10:42 AM #2Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
The stuffers for the 5 petal cages will net you the same gain as 060 off the front half,the spacer is good for holeshot and midrange,make sure it will fit under your cover,It moves the front end forward 1 inch,They can be used together,Chris
02-26-2021, 12:07 PM #3
I put the CCM stuffers with reeds in an XR6 a while back. I did the reeds first and noticed improved EVERYTHING from idle to WOT. Then i added the stuffers. I got a pretty good increase in low end torque with the stuffers. I never added a spacer though. A buddy runs one of Chris' 1" spacers on his 2.5 and said it woke the mid range up big time.
02-26-2021, 12:09 PM #4
02-26-2021, 02:25 PM #5Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Mostly bottom and mid
rgsauger thanked for this post
03-06-2021, 05:55 PM #6
If the stuffers are for bottom and mid, will they take anything away from the top end? I have a 2001 280hp EFI. Would a 1" plate do anything for this motor?
03-08-2021, 09:02 AM #7Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Mercury sold a 1 in spacer for the 260-280-300 drag motors,made of aluminum,around 5-6 pounds if I remember right.Ours weighs 1 1/2 pounds...and insulates heat from the front of the motor,good for air density and more plenum area.More power across full rpm band on 7 petal motors.The stuffers raise crankcase compression(same as milling front half,only more).The 4/5 petal spacer plate vastly improves the path from intake to reed on a carb or laser injected motor so better acceleration,but top end will be governed by carb and exhaust size.
25two.stroke liked this post
changin my 245 carb mota to a horn mota????
By boilerdawg in forum Technical DiscussionReplies: 7Last Post: 05-30-2008, 12:07 PM
