Results 1 to 15 of 17
    Jun 2020
    long island
    Question the big question
    Whats the difference between a mercury 150 and a 150 black max xr2? has anyone ever dynoed a 150 xr2 whats the power at the prop?
    thank you and god bless your souls
    Jun 2018
    Floating around
    It depends on what year 150. The 150’s came in 2.0, 2.4, and 2.5L sizes. The XR2 is a 2.0L that was sold for a coupla three years in the late 80’s. Compared to a 150 black max 2.0L of the same vintage the XR2 came with a few upgrades; bigger carbs, better tuner and plate, and a few other doo dads. The XR2 made around 160hp maybe a bit more. I had a 2.0L that I ran for one year, great motor. I still have an XR2 I have yet to run
    Feb 2011
    HUDSON, FLORIDA
    i have a 83 150 2.0, looks like it just came out of the crate. ran 65 on a shadow bb.
    xr2 had the 200 tuner and larger carbs, great little motors.
    Jan 2021
    Lake Muskoka,Ontario
    So what's the diff. with my Daughter's '02 150 XR6?
    Lake Coochiching, Ontario
    XR6 was a 2.5L, XR2 was a 2L. More cubes meant more torque. The XR2 had the standard gear case, 2:1 gears. The XR6 could have the standard gear case with 1.87 gears, or the smaller 4.25” gear case with 1.78 gears.
    Probably wrong, but didn't the XR bass motors come with a timing adv. box that gave a few degrees more above 5700-5800 rpms?
    I had an XR4. It had a timing box that retarded the timing to limit HP. I don’t know if the XR6 was the same. If it matters, the XR4 was 2.4L
    Jan 2021
    I believe my Daughter's '02 XR6 shows a 5,800 r.p.m. red line!
    Jun 2018
    Floating around
    XR2’s sound nasty, one of the meaner sounding stock fishin motors
    Jan 2021
    Quote Originally Posted by Muskoka2 View Post
    Correcting myself-5,600 r.p.m.!
  12. #12
    When I had my XR4 on my SS2000, it would not pull more then 6000 rpm, even with a 24” prop
  13. #13
    TX......somewhere?
    makes no difference with that motor.. its a new and improved "lectronic" motor that ya have no control over.............
  14. #14
    It was possible to remove the timing box and get more rpm out of an XR4. Was the XR6 the same?
  15. #15
    TX......somewhere?
    after lookin' inside tha xr4 block decided it wouldn't be worth it... had a coupla "switch box" xr6's that could easily turn up 65/6800 plus (whatever tha stock portin' would give up).. lite weight boat, little prop, 2 ta one's and jacked up a bunch..
  1. Merc tach question,and charging question
    By hydroguy21 in forum Electronics, Audio Systems, and Wiring
    Last Post: 07-24-2011, 04:56 AM
  2. Hydrostream reintroduction question Question
    By roostertailn826 in forum General Boating Discussion
    Last Post: 09-18-2009, 01:45 PM
