Results 1 to 14 of 14
Thread: 225 pmx been sitting
02-25-2021, 05:20 PM #16000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,536
- 435
- 67
- 435
- 463
MY pmax sitting for 8 mths, good batt, trying to start, but wont. i remember the fuel pump run in the past, for a few sec., but now silence with ign. on. im just gettin some fire and smoke. ptimer bulb pumped up. shouldnt i have 36lbs key on, not running? just sputters? havent touched throttle, stock efi. had 50-50 mix pump/ 100ll when stored. any ideas would be appreciated
02-25-2021, 05:55 PM #2
Fuel pump should run for a few seconds. If not probably the driver. I know there is a way to bypass by adding a ground wire but you need to talk to someone that knows for sure.
RockTeam Junk
02-25-2021, 06:09 PM #3
Do you have a fuel pressure gauge at the rail? Whats it reading?. Could have fouled the plugs if too much oil in fuel and been sitting
02-25-2021, 06:48 PM #46000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,536
- 435
- 67
- 435
- 463
02-25-2021, 06:55 PM #56000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,536
- 435
- 67
- 435
- 463
02-25-2021, 07:08 PM #6
Driver, he is referring to the fuel pump driver circuit in the ECU.
Yes, with key on the high pressure pump should run for 20 or 30 seconds I think. During that time you should have 39 psi and then it will slowly leak down as time goes on and the pump is off. It does sound like the pump failed or the driver is down.
Take the 2 wires off the fuel pump and check to see if you get 12 volts at the pump when you key up. If not then the driver is down. If you have the power then something is wrong in the VST
You can bypass the driver to power the pump straight from the keep or put a separate switch on the dash...or send the ECU to be repaired.8' Yellow Jacket - 25 hp Mariner
1990 Collins Mirage - 15" 260
25 hp Merc with dry side pipe
KIRCHNER thanked for this post
02-25-2021, 07:16 PM #76000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,536
- 435
- 67
- 435
- 463
so put a test light between the 2 fuel pump wires? can i leave them connected? i have a brucato acu. if that means anything. if i have power that means acu good? but pump froze up??
02-25-2021, 07:21 PM #8
Test light isnt the best unless it is one of the fancy ones that show voltage...you gotta make sure you have 12+ volts. Even so, a bad wire could provide 12 volts and not enough amperage...the Brucato is good but they still lose drivers. My ACU I have on a bridgeport lost the fuel pump driver while they were testing it at Brucato...I told them not to fix it cause I have a Bosch pump in the boat and don't need it...
you could leave them connected. To confirm though, you do not hear the pump tun on even with the cowl off?
02-25-2021, 07:38 PM #95000 RPM
- Apr 2017
- Holland,MI
- 350
- 19
- 16
- 34
Ground one terminal on vst pump, run a wire from the other lead to the purple wire off the engine harness. When you turn the key to "on" the pump should run, if it doesn't the pump is bad. They are known to go out. You are better off buying a whole vst than replacing just the pump.
KIRCHNER thanked for this post25two.stroke liked this post
02-25-2021, 07:47 PM #10
Yeah there's some VSTs for sale here if you need them. Or I have 2 or 3 somewhere...
02-25-2021, 08:08 PM #116000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,536
- 435
- 67
- 435
- 463
Ill remove cowl tomorrow, check for 12v,at pump, if no ill put 12v to pump, hoping to hear it run. thanks guys,ART.
02-25-2021, 08:12 PM #126000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,536
- 435
- 67
- 435
- 463
02-26-2021, 04:18 PM #136000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,536
- 435
- 67
- 435
- 463
ITS ALIVE! Im used to hearing my 2.4 220, where pump is outside the VST. the 225 is very quiet, had to remove cowl. She kicked off, after some cranking. cant thank enough for all the response, what a great brotherhood of HP boaters.
02-26-2021, 10:02 PM #14The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 338
- 19220
- 3 Post(s)
...and only use REC 90 gas if you let it sit around without using it...
So I'm sitting at home........
By Sonik in forum The Scream And Fly LoungeReplies: 2Last Post: 06-18-2013, 08:24 PM -
sitting in a hospital bed
By sunapeeboater in forum The Scream And Fly LoungeReplies: 27Last Post: 10-21-2009, 12:04 PM -
OMC Tech: no spark after sitting
By dnyhuf in forum Technical DiscussionReplies: 6Last Post: 08-24-2008, 08:23 AM -
been sitting up a while
By bec in forum Technical DiscussionReplies: 3Last Post: 07-26-2006, 09:02 AM
