Results 1 to 15 of 19
02-24-2021, 01:47 PM #1
How much HP does it take to push a V-King to 100?
I know set up and weight are major factors but as a general guide what do you guys think is the HP needed?
02-24-2021, 01:59 PM #2Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
I had a Bridge Port (245 hp) on mine and it ran right at 100...But it turned close to 7k doing it, and all that was in the boat was a little battery and (2) 6 gallon tanks.
LakeFever thanked for this postStar1, 25two.stroke liked this post
02-24-2021, 02:07 PM #3
Solid thanks. I'm rebuilding an FF 200 efi and figure I might as well add power while Im at it. Trying to get a target in mind and then mod accordingly. 250ish hp it is then
02-24-2021, 02:20 PM #4Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
Well, I ran a "98" 200 FF EFI on mine and got 86 with a worked 28p lightning ET. Keeping the rpm close to 6k. My 225 3.0 is a little faster at 90. 6k also. My hull is blueprinted (no hook) and all the weight is right on the transom. You will have to spin it up for that kind of speed. And surface the lower right at the pad.
LakeFever liked this post
02-24-2021, 03:09 PM #5
I would leave it stock and repower but I had a pinched fuel line and tightened up two holes. Sucks but what can ya do? I might switch it to 16amp so I can spin it higher
02-24-2021, 06:15 PM #6
A good 225 promax with no limiter will get you there with a light load and good set up,and yes on the 16 amp system.
LakeFever thanked for this postbaja200merk, Forkin' Crazy liked this post
02-24-2021, 10:35 PM #7
Definitely love seeing a hydrostream thread at the top after not being on here for a few days.
I say keep going with that 250hp project, jack it to the moon, and let a sharp nasty cleaver do the rest!!! You'll have zero prob hitting triple digits1977 Hydrostream Vector 2.5 Promax
02-25-2021, 07:47 AM #8
I have a buddy with a YT bottom Vking and he runs a stock 260, 99.7 mph so far. Boat is recored and setup light, center steer no back seat etc.
02-25-2021, 01:00 PM #9
Last month mine ran 92 with 20gals of gas, seating for 4 although I was the only one in it, and 30P Hoss.
02-25-2021, 01:01 PM #10
Oh yeh….245 carb motor too
03-05-2021, 09:08 AM #11
if you have a straight/stiff bottom and build an xr6 case you probably get there with 200hp!non bp 2.4/7pedal. I was seeing 93gps with full interior and 110lb. passenger with the first prop I tried 26 cleaver!
03-05-2021, 07:20 PM #12Team Member
- Lake Coochiching, Ontario
- 7,710
- 269
- 472
- 1542
- 6 Post(s)
Hi Don, long time no see.
03-06-2021, 08:00 AM #13
Hi David, havn't been here for a while , Ted's passing brought me over to read some of his other friends experiences with him!
Capt.Insane-o liked this post
03-06-2021, 07:34 PM #14
My YT ran 104 on the limiter with a 225pm. A slightly warm 2.5 200 should do it...the again going fast is more about setup than brute hp.
1989 21' Skater - twin 2.5s
1986 Cougar 21MTR, 15" 300XS - sold
2002 TUFF 21 (#0.1), 300xs - sold
1986 Valero YT, 225 Promax - sold
1987 Viper, 140 cross flow - sold
03-07-2021, 09:21 AM #15TRANSPORT SERVICE...UP TO 33 FEET....YOUR TRAILER OR MINE... FULLY INSURED...............
DOT & CDL COMPLIANT $500,000.00 CARGO & 1 MILLION LIABILITY
LIVE LIFE ON THE EDGE,LESS CROWED BETTER VIEW
What causes bent push rod in gm 350
By delawarerick in forum Technical DiscussionReplies: 9Last Post: 06-10-2015, 09:04 AM -
push button start
By thunderstruck racing in forum Technical DiscussionReplies: 1Last Post: 08-31-2010, 09:13 AM -
Push or Pull
By ShoreThang in forum Technical DiscussionReplies: 2Last Post: 06-10-2004, 09:52 PM -
Push Lock
By Liqui-Fly in forum Technical DiscussionReplies: 6Last Post: 05-28-2002, 02:12 PM -
How far can you push a 280 ?
By KeithRichards in forum Technical DiscussionReplies: 14Last Post: 08-23-2001, 11:04 AM
