Results 1 to 15 of 41
Thread: Seized Steering Tube Bolt
02-24-2021, 01:14 PM #16000 RPM
- Aug 2015
- Southeast
- 1,068
- 134
- 79
- 48
- 614
Any master mechanic tips and tricks to get the bolt out of the steering/tilt tube? Bought a used ROS mid and the bolt is stuck. Any advice other than penetrating oil and/or heat? I was told to just leave it there and mount to it. I'm not seeing how hydraulic steering can be mounted without the bolt being able to slide back and forth?
I'm referring to the long stainless bolt that goes through the entire clamp.Bullet CC w/ 225 Promax - Sold
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship"
Blazer 650 Pro Tour
02-24-2021, 01:23 PM #2
Grab it with a big set of vice grips use some cheater bars to really clamp down on the vise grips and then a cheater to give you leverage to try and spin it after heating??
02-24-2021, 01:55 PM #3Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
Heat it and it will come out. Put a couple of nuts on one end (to protect the threads) and hit it with a hammer. Get it to the end of the tube and go to the other end and do the same again. Squirt some lube each time. Back and forth. When out, slot a dowl rod and slip some 80 grit into it and sand the tube clean. Done it many times. Only heat the rod, not the clamp. Propane torch or very careful with an oxycet torch set.
02-24-2021, 02:49 PM #46000 RPM
- Aug 2015
- Southeast
- 1,068
- 134
- 79
- 48
- 614
Thanks guys. I've tried PB Blaster and a hammer with a nut on the end so far. Hasn't budged. Have it sitting on its side so oil can seep in maybe. Will try again this eve. So it's better to heat the bolt, not the surrounding material?
Blazer 650 Pro Tour
02-24-2021, 03:23 PM #5
That hammer in the picture on the ground is not big enough lol
As far as the heat, I would think heating the bolt would mean all the calcium surrounding the bolt would also get hot...you may not get all of that by heating a part that is separate from the bolt...
Since you got it on it's side, heat it up and use an air hammer to try an shake the calcium loose, when you see it snowing down you know you are making some progress..
02-24-2021, 03:29 PM #6
I have had some luck on stuck bolts without using PB baster because you want the corrosion to dry out not get wetter to have to then dry it again...
02-24-2021, 03:33 PM #76000 RPM
- Aug 2015
- Southeast
- 1,068
- 134
- 79
- 48
- 614
Yeah, I'll get my bigger hammer out and try some heat on each end of the bolt. At this point I've been letting the PB soak in for several hours so sort of hard to turn back now.
Blazer 650 Pro Tour
02-24-2021, 06:55 PM #8
You can mount a seastar modern ram to it without removing it. That is true. If you wanna take it out you could take out the entire tilt tube and replace it...thats the easy cheat. Buy a new tilt tube and ditch that one. I may have one you could have...would have to look on Saturday.
Ive always been able to get them out with lots of MAP gas heat and putting 2 jamb nuts on the thread and twisting it. But that typically melts the bushings in the tilt tube and then you are back to my first recommendation of taking out the tube.8' Yellow Jacket - 25 hp Mariner
1990 Collins Mirage - 15" 260
25 hp Merc with dry side pipe
02-24-2021, 07:13 PM #96000 RPM
- Aug 2015
- Southeast
- 1,068
- 134
- 79
- 48
- 614
Don't see how i can get the nut off the tube to get it out. They are recessed in the clamp so can't get a wrench on them? Don't have sockets deep enough to reach over the bolt all the way to the large nuts on either end.
Didn't heat and bang on it this eve. Got sidetracked on some other stuff.Bullet CC w/ 225 Promax - Sold
Blazer 650 Pro Tour
02-24-2021, 07:21 PM #10
You gotta put a socket on it. Sometimes one side sits in locking tabs while other side is free to turn with a socket.
02-24-2021, 07:45 PM #116000 RPM
- Aug 2015
- Southeast
- 1,068
- 134
- 79
- 48
- 614
I'll try heat and hammer first. Then move on to trying to find a 3 or 4 inch deep socket.
Blazer 650 Pro Tour
02-24-2021, 09:19 PM #126000 RPM
- Nov 2006
- 1,495
- 13
- 129
- 70
- 626
- 35 Post(s)
02-24-2021, 09:36 PM #13The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
02-24-2021, 10:28 PM #145000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Maybe heat and cool it a few times, then try banging on it when it is cool so it doesn't get too distorted. Use oxy-acetylene, I doubt a regular propane torch would be enough.
02-25-2021, 04:22 AM #15
Ive had one of these issues and in my case the the motor was not much good anyway so I dumped it.
However, if that wasn't an option Id have found a piece of fuel line that would fit over the tube thread and filled it with WD 40 or CRC with a gravity head on it for a week.
Probably thread tape the tube thread so it sealed on the fuel tube.
Then find a couple of really good nuts to wind onto the rod thread right to the shoulder and proud of the thread end.
Probably warm the lot up also to let the penetrating oil get in there and hammer it out as carefully as possible.
2.5 Merc Steering Wing Plate and Tilt Tube Steering Pin WPM
By gqchris in forum Misc. Parts and AccessoriesReplies: 14Last Post: 03-19-2019, 11:48 AM -
Mercury V6 dual oposed steering mounting kit and Allison long steering shaft bolt
By JWTjr. in forum Parts WantedReplies: 0Last Post: 04-25-2014, 03:58 PM -
1994 155hp steering seized, over heat alarm
By cracker in forum Props, Setup, and RiggingReplies: 4Last Post: 05-17-2012, 05:57 AM
