Results 1 to 6 of 6
02-22-2021, 02:08 PM #15000 RPM
- May 2001
- Maine
- 982
- 35
- 42
- 170
Anyone tried a 4 blade ProMax Prop on a STV?
Just curious as to the prop/cons.
02-23-2021, 05:38 PM #25000 RPM
- Feb 2010
- wisconsin
- 475
- 32
- 21
- 117
- 168
probably have a bit more stern lift that what your used to depending on what gearcase your using on it.
02-23-2021, 06:24 PM #35000 RPM
- May 2001
- Maine
- 982
- 35
- 42
- 170
I was thinking it may help get over the hump with the heavy 3.0L motors but then you would be limited in height do to the thru hub exhaust.
02-24-2021, 01:49 AM #45000 RPM
- Feb 2010
- wisconsin
- 475
- 32
- 21
- 117
- 168
02-24-2021, 08:53 AM #5
Agree with wicheckmate, the ride is much better with a Pro Max versus a solid hub as well, much smoother thru waves
2003 Triad RR 280 ROS
02-25-2021, 12:20 PM #6
comparable 4 blade ss prop to a BRP rogue 4 blade?
By zwalls in forum Props, Setup, and RiggingReplies: 0Last Post: 09-03-2011, 09:49 AM -
New 6 blade CNC, stager blade, prop
By appsyscons in forum Props, Setup, and RiggingReplies: 11Last Post: 07-09-2008, 10:08 AM -
3 blade laser II prop or 4 blade offshore?
By Air Dog in forum Props, Setup, and RiggingReplies: 7Last Post: 04-05-2006, 11:56 AM
