Results 1 to 7 of 7
Thread: How to ID 2.5 Sporty's
02-22-2021, 07:47 AM #1
I just bought a used 2.5 SportMaster, 1.87, RH w/Swept Skeg, my question is, how does one ID a Sporty when a parts order is needed since there aren't any obvious marks, numbers etc on the case ?
I found a parts listing of Sporty's ranging from/to: OG367000 to OG856999, but again no way to ID what I have against these S/N's. Appreciate any help as this is very new to me.
Thanks
aj06bolt12r liked this post
02-22-2021, 10:48 AM #2
It is my understanding they are all the same. Only differences is offshore case (skeg), LH or RH drive, gear ratio, 15" or 20" drive shaft.
02-22-2021, 04:45 PM #3As Brad said, other than the obvious differences, the early ones had a small prop shaft.
is gone
02-22-2021, 05:34 PM #4
There are bearing differences in the fwd gear...no way I know how to tell other than taking it apart.
Is there a specific part you are looking to find the correct p/n? Just pay attention to all the parts, study the diagram and ensure it matches your unit perfectly prior to ordering.8' Yellow Jacket - 25 hp Mariner
1990 Collins Mirage - 15" 260
25 hp Merc with dry side pipe
02-23-2021, 03:13 AM #5
Thanks all, Mine is a small shaft and has the swept skeg so I'll assume Early Offshore Case. I don't need anyparts as of now but just wanted to understand what I've got before a part maybe required down the road. Thanks again, appreciate it very much
02-27-2021, 03:24 PM #6
As I understand it, the big bearing on fwd gear is a ratcheting case and the smaller bearing on fwd gear is non ratcheting. When in fwd gear if you able to turn prop by hand a get a click click in backwards direction its a ratcheting or big bearing housing
Peter Thomas
02-27-2021, 04:40 PM #7
Cle/Sporty
By ttopping in forum Technical DiscussionReplies: 4Last Post: 03-18-2018, 10:22 AM -
2.5 Sporty 1.62
By GregAdams in forum Technical DiscussionReplies: 2Last Post: 02-04-2017, 08:36 PM -
2.5 Sporty
By Varmint in forum Lower UnitsReplies: 6Last Post: 02-12-2016, 07:17 PM -
Mercury Tech: sporty
By justinn in forum Technical DiscussionReplies: 0Last Post: 05-09-2009, 10:57 AM
