Results 1 to 12 of 12
    Sep 2017
    Ashland city tn
    Compression vs octane
    Me and a buddy just put together and ported promax , put stock heads on for now, but I have a set of oring heads that I can get the oring groove milled flat and i get around 170 ,180ish lb cranking compression roughly, what kinda fuel octane should I run with that kinda compression? I installed head studs so I can swap heads out little easier
    Can I do a mix of 93 and av fuel ? If so what kinda ratio. And what is the norm octane for av fuel
  2. Likes Baker343 liked this post
    Sep 2007
    Pensacola FL
    Most av fuel is around 100 octane .. If your at 180psi, personally I’d stay close to 100. Your safe cutting it back some but I wouldn’t go much lower than 98 depending on how hard your turning the motor .
  4. Thanks Merc 2.5 thanked for this post
    Likes Merc 2.5 liked this post
  5. #3
    Sep 2017
    Ashland city tn
    Yep seems like gonna be 26cc. 180ish lb.
    Ill have 2 sets of heads and a dedicated tank to 26cc heads. Will the plugs ,pistons read like 93 fuel?
    Los Angeles Cal.
    I’ve used AV gas +91 it works ok. If I run 175 to 180 compression I run 2 gallons 110. 3 gallons 91 pump gas. 98.6 Octane.
  7. Thanks Merc 2.5 thanked for this post
    Likes Merc 2.5, 25two.stroke liked this post
    What is your exhaust port height?
    Apr 2018
    Maine/Ma
    in a 15 gallon gas caddy, I mix 5 gallons of VP C-12 (108) with 10 gallons of 90 octane Recreation fuel (no ethanol), yields about 96 octane.
    if you can get AVGAS near you then stick to that all the time. it is the most reliable fuel anywhere in the world. the octane rating will not change . even race fuels can have a change in octane , but NOT avgas..
    its got very expensive here int eh uk , or i would run it anyway..
  11. Likes Michael J Giesler liked this post
  12. #8
    Oct 2010
    Harrisburg,Pa
    Here is a good mixing site for fuel.
    http://www.bazellracefuels.com/Calcs/OC1.htm
  13. #9
    Sep 2006
    Check fuel densities also
    May 2002
    Lake Havasu City AZ
    My opinion, ave gas and premium is better than ave gas alone. I had better luck with a 50/50 mixture than straight ave.
    Quote Originally Posted by rude tim View Post
    Octane should follow compression ratio . Too much octane and not enough squeeze will be slower than a proper fuel for the job.
    I ran VP- NOS in my car. 120 octane / SG .709 / on motor it was a pooch. A pair of 300 HP kits on top .. no worries , no new pistons every other race ..
  16. #12
    Sep 2017
    Ashland city tn
    Sorry guys. I been down for while. Just got new phone and can see everything again as for my port height. It's nothing crazy. I can get a exact #bfrom machinist. I put head studs in so I can swap heads easier , just lookin for a good compression # vs octane # I have av fuel not far from me. Not even sure what that octane is
  1. 160 psi Compression / Octane
    By DangerNewb in forum Technical Discussion
    Last Post: 06-29-2018, 06:52 PM
  2. OMC Tech: Necessary Octane - V8 with 145 to 150 compression?
    By Li'l Toy in forum Technical Discussion
    Last Post: 06-01-2015, 01:37 AM
  3. safe compression with 93 octane and aces octane boost
    By woundedwarrior in forum Technical Discussion
    Last Post: 04-25-2013, 06:41 AM
  4. compression vs. 93 octane
    By MIKEF18 in forum Props, Setup, and Rigging
    Last Post: 04-05-2007, 07:47 AM
  5. Octane/Compression on a 300 ??
    By StrokerOMCSS in forum Technical Discussion
    Last Post: 09-08-2006, 09:43 PM
