Results 1 to 4 of 4
    Nov 2004
    Evinrude v8 flywheel
ID:	482886I have an spare engine and noticed that the flywheel is different from the others that I normally see. Refer to attached picture. The flywheel has the magnets integrated and the stator is different. There is no part number etched to check for specifications. Could anyone have any knowledge of them.
    Sep 2011
    maryland
    Have you pulled it to see if there are numbers on the underside?
    Nov 2004
    Yes, no part number was identified. Someone mentioned that it should be a counter rotation engine. In 1985 the engine rotates counter. Interesting.
    Dec 2001
    Turn the key..... see which way the Flywheel turns.
  1. OMC Tech: Evinrude V8 flywheel question
    By Banana Boat in forum Technical Discussion
    Last Post: 08-11-2016, 06:22 AM
  2. Evinrude Flywheel nut?
    By CNT in forum Technical Discussion
    Last Post: 04-19-2010, 05:10 PM
  3. what evinrude flywheel do I have#581472?
    By roadkill636 in forum Technical Discussion
    Last Post: 03-09-2008, 03:55 PM
