Results 1 to 4 of 4
Thread: ECU Replaced
02-20-2021, 09:20 AM #1Member
- Jun 2009
- NYS
- 52
ECU Replaced
If an ECU is bad on a 275HP Verado and I replace it with a ECU from a 300HP Verado will it produce the 300HP. Plug and play as long as I run 91 octane. Will it put out the horsepower
02-20-2021, 10:25 AM #2Member
- Jun 2009
- NYS
- 52
Straight forward question.
02-23-2021, 03:33 PM #3
www.InjectorService.com
Call/Text - 204-326-0390
02-23-2021, 05:16 PM #4
More or less yes.
Your going to be replaced...
By CUDA in forum The Scream And Fly LoungeReplies: 8Last Post: 02-17-2019, 05:28 PM -
Just replaced water pump.. Does this look okay?
By soundguy in forum Technical DiscussionReplies: 5Last Post: 06-23-2015, 05:20 PM -
Merc 200 XRi ECU Replaced, Now What TPI Setting to Use?
By Duper in forum Technical DiscussionReplies: 18Last Post: 07-11-2014, 09:02 PM -
16' Allison Transom Replaced
By scrmn3 in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 06-05-2012, 08:14 PM -
Can 2pc driveshaft be replaced with 1pc?
By Intercoastallady in forum Technical DiscussionReplies: 2Last Post: 05-28-2006, 04:53 PM
