Results 1 to 6 of 6
Thread: Merc tech : 2.5l optimax tuning.
02-20-2021, 09:06 AM #1
Hi , any good treads of information of knowledge of the different models and access of software to tune them to different states of tuning? Ultimately making a optimax drag from a 150 hp optimax... seems like reeds are smaller on the 150hp compared with the 200xs. 2 gen 200xs have 260 porting ? Whats the rpm/ HP limits of the optimax 2.5 system. Tweaking with higher air and fuel pressures?
Last corner in Flosta boat race 90mph.
http://www.youtube.com/watch?v=WbqlgOB3ulQ
Espen Hilde
Hosle Norway
Mobile:
+47 90700200
02-21-2021, 02:56 AM #2
There is software but very expensive, i know van ackeleyen in belgium has it
but turning a 150 optimax into an optimax drag?
you could use the SSt spec to copy that into the 150 ,get an 200XS ecu and fuel pressure regulator and maybe you get somewhere
my vote would be into making the 150 optimax into an actual steel sleeved drag
the block would need to be decked for gaskets or use 280 heads
install a front injection plate with the old ignition stuff brucato ecu and lots of oil can,s
02-21-2021, 03:18 AM #3
Optiflop drag :P
02-21-2021, 08:20 AM #4Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,637
- 606
- 920
- 1698
- 7133
- 3 Post(s)
The 2.5 opti (2005) is already a high strung deal making 247 HP and good torque due to the fact thats direct injected. The main reason they eat pistons is dentnation, they require fresh 93 to stay happy and Mercury only produced 100 of them.
02-22-2021, 03:34 PM #5
I think you missed something here. He is trying to take his 150 Opti and turn it into something like the 2.5XS
I think a good start on this project would be to get the following parts. I don't know how the port timing or reeds are on the 150 vs the 2.5xs, but the following parts will be needed.
1. 14 PSI fuel pressure regulator
2. Red fuel injectors
3. Grey air injectors
4. 2.5xs ECM
Blake
www.InjectorService.com
Call/Text - 204-326-0390
02-23-2021, 01:19 PM #6
this is an injector plate i was working on
plan was to build a custom carbon fibre downdraft intake in such a way you can custom tune the intake tract inside the plenum
this way the helmholtz effect would be there for the entire rpm and load range instead of only at full throttle
but as always earning money keeps getting in the wayLast edited by PanRonnie; 02-23-2021 at 03:12 PM.
Capt.Insane-o liked this post
MERCURY TECH: Need help with various problems Optimax 225 - 2001
By kinobe in forum Technical DiscussionReplies: 0Last Post: 05-17-2015, 05:58 PM -
Mercury Tech: 2.5L 280 Merc Tuning
By Catch This in forum Technical DiscussionReplies: 9Last Post: 05-13-2010, 06:59 PM -
tuning on my 200 merc
By banchee6 in forum Technical DiscussionReplies: 1Last Post: 08-01-2009, 07:08 AM -
OMC Tech: E-Tech tuning
By espen22 in forum Technical DiscussionReplies: 0Last Post: 05-25-2009, 04:35 PM -
Optimax tuning
By Lars T in forum Technical DiscussionReplies: 3Last Post: 09-22-2005, 06:13 AM
