Results 1 to 3 of 3
    Plainville, CT
    WMH Versus WMV Carbs
    Any benefit to the WMV carbs over the WMHs? Like better idle, or better performance, or better fuel mileage?
    I see the WMVs have 6 idle air jets and no progression jets for all three carbs, whereas the WMHs had only 3 idle air jets and 6 progression jets. Seems fewer jets on the WMVs may be an advantage.
    Although keeping track of all of the different sizes on the WMV idle jest may be a pain. Also, the idle screw adjustments are strange because some are 1 1/2 and some are 1/78 turns. This could drive you crazy too.
    Jun 2009
    Bristol, Connecticut
    been reading older posts and someone said the guys on here mostly run the older WH because they are easier to "tune", maybe because like what you said many jets and functions on the newer ones to get right
  3. Thanks Glastron1987 thanked for this post
    Likes Glastron1987 liked this post
    Sep 2017
    Ashland city tn
    I haven't run wmh but I have run wmv18s (200) which is supposed to b the best wmv and my wh46 tuned to my motor ,run alot better , more rpm, more snappy imo
  5. Thanks Glastron1987 thanked for this post
  1. 2.0 versus 2.5
    By Glastron1987 in forum Technical Discussion
    Last Post: 07-14-2019, 03:28 PM
  2. Mercury Tech: 245 versus 260
    By bullwhipjkg in forum Technical Discussion
    Last Post: 02-25-2010, 02:45 PM
  3. 50:1 versus 25:1
    By capnzee in forum Technical Discussion
    Last Post: 08-16-2007, 03:41 PM
  4. C-5 Z-06 versus C-6 which is better
    By Charlie M in forum Other Motorsports
    Last Post: 12-22-2006, 11:31 PM
  5. OMC v6 200 versus 225 ('96)
    By tcsmith315 in forum Technical Discussion
    Last Post: 08-01-2003, 05:42 PM
