Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 57
    Brushing gell is not pre thinned like an airless equipment gell that is pre thinned. Thin the "brushing" gell with styrene and spray away. Remember to add only the amount of mek needed for the gell, not including the added thinner.
    Jun 2018
    Floating around
    That makes perfect sense I got it now thanks fellas. I add wax or use PVA on the last coat to dry. I have glassed a bit in the old days but this is literally the first can of gel coat ive ever owned.
  3. #18
    Jan 2018
    Not a tourist in Forida anymore.
    surely you mean MEKP, not mek? too easy for a newb to read this and screw up a project....
  4. Likes powerabout liked this post
  5. #19
    Jan 2018
    personal pet peeve.....
    too many folks talk about "drying", whether it be referring to resin and fiberglass, epoxy, carbon fiber layups, etc.
    there's only a few things in life that'll DRY....
    your clothes, LATEX FUGGIN PAINT, and the dishes in the strainer....
    ANY SOVLENT BASED PAINT, FIBERGLASS LAMINATIONS, OR EPOXIES WILL "CURE"......
    Just because you can put ypur dirty dick beaters on it, and not leave finger prints, doesn't mean its "DRY"....
    It hasn't CURED YET...
    There's a chemical reaction taking place because there was a catalyst added to a resin, or a monimer, or a polymer, and you set off a chain reaction...
    it needs time and the proper temperature to CURE. It doesn't DRY like your socks on an old fireplace....
    read the damned instructions on the packaging, and FOLLOW THEM.....
    but, do whatever you want to, you will anyway.
    oh, and PVA will dry... The alcohol (the solvent in the mixture) will evaporate if the ambient temp is warm enough and it will DRY....
    happy friday kids. good luck with your projects.
  6. #20
    Jun 2018
    Floating around
    Lol @ dik beaters. I hear ya loud and clear I will ask more questions as I move ahead. Thanks again
  7. Likes Headless Hula liked this post
  8. #21
    Jan 2018
    i've had a very recent experience with someone not following instructions.... they had a "less than desirable result"...
    It didn't get layed on me, but there was a whole bunch of dicking around that could've been avoided had they simply LISTENED....
    I'm happy to show someone how to do something that I may be proficient at, but when you don't follow the instructions, then squack about the results, I'm not going to have 2 seconds to hear about it....
  9. #22
    Jun 2018
    Floating around
    Can’t argue with that. I’m doing my best to wise up and do a good job of this build. At some point we all have to dive in and get after it. The support is greatly appreciated
  10. #23
    Yes, methyl, ethyl, ketone, in solution with organic peroxide. Correct , mekp. But, don't get it on yer dik. as hula sez.
    Jun 2018
    Floating around
    Lol I’ll be sure to keep it off the Johnson. In fact I hope to wear gloves for the whole process. With covid it’s hard to get rubber gloves. I was thinking chem resistant neoprene but one pair costs more then ten pair did a year ago. Hot dang that rots my socks off. Not sure nitrile are any good for these chemicals.
    maybe dish washing gloves?
  12. #25
    Minneapolis MN
    If you're planning to spray the gel over the newly completed core/floor may I suggest brushing/rolling? At least the first coat. I found that spraying gel over raw glass tended to result in a lot of little pin hols, negating the whole process, whereas a roller/brush didn't give me any of that.
    Keep in mind I didn't thin the gel at all when sprayed.
    Just an observation I had with my project.
  13. Likes Forkin' Crazy liked this post
  14. #26
    Jun 2018
    Floating around
    Thanks for looking out Tnels I appreciate it. I am going to pour and spread the gel over the core under the floor i've read your thread many times over LOL. I will have plenty of gel left though and I thought gel was gel until I picked it up and it said "brushing gel" right on the label so I got a little unsure and thought to ask what if any differences there are aside from waxed non waxed. I have some other boats that I can use it on and would like to spray hence this thread.
  15. Likes tnelsmn liked this post
  16. #27
    Jan 2018
    got the port side sprayed this afternoon.
  17. Likes tnelsmn liked this post
  18. #28
    Hula, what thinner are you using?
    Jan 2018
    just a tiny amount of acetone. less than 10% Using a home depot gravity feed gun with a 2.2 mm tip @ 35 psi. I only mix 12oz at a time.
  20. Likes LakeFever, XstreamVking liked this post
  21. #30
    Sep 2002
    Dublin, Ireland
    Brushing gel is standard gel for hand layup, can be brushed or rolled. Spray gel is a thinner gel for spray application. Yes you can thin brush gel enough to spray given right conditions and equipment. But you will get better results from spray gel.
    Regarding finish, I've found a much higher quality finish with brush gel in a mould. Spray can have microporosity/ tiny bubbles which can appear hazy if you get solvent entrapment or contamination.
    Are you using the gelcoat in a mould or repair / resurface?
    Power Marine 650 Offshore Race, Yamaha 130 Pro-V
  22. Likes LakeFever liked this post
  1. Real base coat / clear coat in a spray can results.
    By Mr. Demeanor in forum General Boating Discussion
    Last Post: 04-16-2012, 02:43 PM
  2. Air Brushing?
    By Needforspeed303 in forum General Boating Discussion
    Last Post: 10-30-2005, 09:18 PM
  3. Brushing on Gelcoat ???
    By PORT in forum Fiberglass and Composites Discussion
    Last Post: 09-14-2004, 12:57 PM
  4. Spray gun for gel coat?
    By cltch in forum Fiberglass and Composites Discussion
    Last Post: 01-30-2004, 11:17 PM
  5. Ever see spray can gel coat????
    By Daytona19 in forum General Boating Discussion
    Last Post: 08-27-2003, 03:15 PM
