Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 57
    Jun 2018
    Floating around
    Spray vs brushing gel coat?
    what’s the difference? Can brushing gel be sprayed?
    Jan 2018
    Not a tourist in Forida anymore.
    I've never seen gel that's been labeled or packaged as "brushing"...
    It either has wax in it or not.
    Now, Ive sprayed, rolled, and brushed gel, and i listed the applications in the order in how flat they layed when applied...
    I tried using a roller on a little project, and kept fiddling with it and ruined the finish. Wound up sanding it all back off and sprayed it.
    I've tried spraying gel with wax, and had satisfactory results,
    This last round, i sprayed it without wax, then let it sit for 15-20 minutes, then gave it a good coat of PVA.
    i was very pleased with how it turned out.
  3. Thanks powerabout thanked for this post
    Likes specboatops liked this post
    Jan 2018
    Jun 2018
    Floating around
    I hadn’t heard of it either but I picked up materials today and it says “brushing gelcoat” on the can so I thought I’d ask. I’ll check the label tomorrow and post what it has in it. I’m pretty sure it said wax added
  6. Likes Headless Hula liked this post
    Jan 2018
    Lemme try the pics again...
    Attached Thumbnails Attached Thumbnails C19D30D9-01A8-443B-B34A-4E591A516E75.jpg
    Jan 2018
    I just filled the holes in my transom to change from a stainless marine setback to a porta. Drilled all the new holes yesterday.
    Jan 2018
    this is after drilling all the new ones.
  10. Likes LakeFever liked this post
    Jan 2018
    blued and block sanded between every grit. Took it to 1000, then buffed it. Pretty happy with it, considering it’s mostly underwater at idle.
    Jun 2018
    Floating around
    Looks great! Are you using blue dykem for guide coat?
    Going to a porta is the best thing you will ever do to your boat. They are just that good....
    Jan 2018
    I’m just renting space from him. Doing all the work myself.
    I meant going to the porta bracket is the best addition to your boat. You doing good work too hula....I have had porta brackets on my guide boats for 20Yrs. Not many around when I bought mine. BTW, still using the same ones! Still work great. New power units and some paint is all I have done to them.
  16. Likes Headless Hula liked this post
    Jan 2018
    Yep. It stays in the tiniest of scratches and ya sand till they’re gone.
  18. Likes LakeFever liked this post
  19. #14
    Jan 2018
    Gotcha. Yea, Scott is a wealth of information and a good guy for sure. I’m pretty fortunate to have landed where I did.
  20. #15
    Jun 2018
    Floating around
    Cool info thanks! Im in the office now pretending to work so I can use the comp not the phone lol. Label says;
    Gelcoat, production brushing.
    Protective surface coating with UV resistance. Unwaxed gelcoat is designed to be brushed against the mold surface when fabricating a fiberglass part. Rec thickness 15-18mils. Surfac remains tacky for up to one week.
    This is what my supplier gae me to use inside the hull over the core etc. What I was wondering is aside from not being waxxed is there anything about "brushing" gelcoat as this is called that makes it different? Can I spray it?
  1. Real base coat / clear coat in a spray can results.
    By Mr. Demeanor in forum General Boating Discussion
    Last Post: 04-16-2012, 02:43 PM
  2. Air Brushing?
    By Needforspeed303 in forum General Boating Discussion
    Last Post: 10-30-2005, 09:18 PM
  3. Brushing on Gelcoat ???
    By PORT in forum Fiberglass and Composites Discussion
    Last Post: 09-14-2004, 12:57 PM
  4. Spray gun for gel coat?
    By cltch in forum Fiberglass and Composites Discussion
    Last Post: 01-30-2004, 11:17 PM
  5. Ever see spray can gel coat????
    By Daytona19 in forum General Boating Discussion
    Last Post: 08-27-2003, 03:15 PM
