Results 1 to 12 of 12
Thread: Flywheel balance?
02-17-2021, 11:14 PM #1
Flywheel balance?
I found some severely corroded wires on the stator on my 2.0. So I pulled the flywheel to replace the stator and trigger. I noticed a broken screw on the flywheel. Is this going to affect performance or cause a harmonic? Should I go through the hassle of getting the remainder of that screw out and replacing it?
02-18-2021, 01:42 AM #2
It's preferable to do it right but probably doesn't matter under 6k
tnelsmn liked this post
02-18-2021, 05:40 AM #3Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
I would fix/replace it. Must be a reason the screw is broken.
02-18-2021, 05:47 AM #4
There’s lots of those flywheels kicking around if the bolt won’t play nice and leave it’s bees nest Id replace it
02-18-2021, 10:11 AM #5
I'll see if I can get it out. Thanks guys.
02-18-2021, 10:32 AM #6
02-18-2021, 10:43 AM #7'78 Hydrostream Viking/'98 225 ProMax
02-18-2021, 03:45 PM #8
Definitely pull the screw out. its not in balance like that.. wont be too hard to get it out.
or drill through it , and then tapa thread into it and put a screw in there...
did you find the offending top part of the screw ?
I would be more worried about that under there than anything else.
02-18-2021, 04:12 PM #9
Bin it and find a different one. Those screws hold the magnet it.
02-18-2021, 07:59 PM #10
Well I got half the screw out. Bottom half is still stuck in there. This is the only blind hole on the whole thing. So time to find another one. It was worth the try.
Phill Jack, I didn't find the head of the screw. This thing has sat for 15+ years so I'm sure its long gone. I had the stator and trigger off and nothing is under there so I'm not worried.'78 Hydrostream Viking/'98 225 ProMax
phillnjack liked this post
02-18-2021, 09:39 PM #11Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
12 nice fridge magnets.
tnelsmn, phillnjack liked this post
02-19-2021, 03:11 PM #12
Found a used one at a local shop. $50 and I was out the door. Easy peasy.
who can balance a flywheel ?
By 985Coonass in forum Technical DiscussionReplies: 6Last Post: 02-02-2019, 01:06 AM -
Flywheel Balance
By seansbaja1982 in forum Technical DiscussionReplies: 17Last Post: 09-13-2012, 12:02 AM -
2.4 flywheel balance - neutral?
By gmacrae in forum Technical DiscussionReplies: 16Last Post: 08-07-2010, 11:05 AM -
Balance a flywheel in Central Fl. area
By Dingie 2 in forum Technical DiscussionReplies: 0Last Post: 08-24-2009, 07:33 AM
