Results 1 to 7 of 7
    SW Florida
    1994 Allison Copy (Activator build 'Alpha') without power rigged for Merc
    1994 Allison copy. This is a Marc Snepp Activator built Alpha.
    I purchased Jan 2019 and rerigged it. Decided to sell without power. It is almost complete. The only thing left is to repaint the floor and the yellow is prepped for paint. The yellow clear was peeling I tried to wetsand and clear but took too much off so the yellow needs to be painted. White gelcoat is in nice condition and shiny. Sale includes 1 pt. of PPG 2 stage Millenium Yellow paint and quart of Rustoleum marine topcoat white paint for inside . Seems like a well built solid boat. I repaired an area that was damaged in the well, added a bow eye with glassed in wood reinforcement backing, (weird, the boat was built with no bow eye) and I glassed in a battery mount under the dash. I also drilled the first transom well drain hole and transom wood was dry (see photos). The corners of the transom have some gel stress cracks but transom and hull seem solid and well built.
    Comp stringer build. Under 400 lbs.
    --Allison racing bucket seat with brand new upholstery and foam.
    --Dual cable steering
    --New TH Marine turn signal trim switch.
    --Gaffrig tach and water psi gauges.
    --Hot foot
    --Kill switch
    --Nydhal shifter
    --24 gallon gas tank
    --Bob's reversible 3"/5.5" manual jackplate
    --New Rule 300 GPH with Water Witch water sensor auto switch.
    Trailer - Load Rite galvanized in excellent condition but no registration. Brand new mounted spare tire. Plastic fenders and New LED tail lights.
    If still for sale when weather gets warmer I will paint the yellow. Comes with PPG 2 stage primer, paint and clear if sold before then.
    Located in Central NJ
    Asking $2000 (no power) rigged for Merc
ID:	482693Click image for larger version.
ID:	482694Click image for larger version.
ID:	482695Click image for larger version.
ID:	482696Click image for larger version.
ID:	482697Click image for larger version.
ID:	482698Click image for larger version.
ID:	482699Click image for larger version.
ID:	482700Click image for larger version.
    2004 Hydra-Sports Vector 2600 - twin 225 Yamahas
  2. Likes Speed Jr. liked this post
    Dec 2001
    Nice.....
    Sep 2008
    charlestown, ri
    PM Sent
    SW Florida
    Sold. Thanks S&F
  6. Likes specboatops liked this post
    Sep 2008
    charlestown, ri
    Just want everyone to know sale went really well. Went above and beyond for me. Great seller thanks again!
    Nov 2003
    Portsmouth VA
    What did you do with the motor?
    18 Talon/2.4 carb SOLD
    26 Deck Boat/250 Merc
    SW Florida
    Quote Originally Posted by 99fxst99 View Post
    It's for sale $2300.
  1. FS: 1998 Allison SS2000 COMP R(Hull/Trailer rigged for Merc)
    By Stone Cold Goat in forum Hulls up to 20'
    Last Post: 05-02-2020, 06:49 PM
  2. New 30' Rage(Activator) Build - FIrst one with Twin OB's
    By Gladhe8er in forum General Boating Discussion
    Last Post: 10-22-2014, 09:15 AM
