Results 1 to 15 of 16
Thread: Monster Marine Lithium Batteries
02-16-2021, 12:45 PM #1Member
- Aug 2017
- Wisconsin
- 33
- 22
I was wondering if anyone has or knows anyone that has used Monster Marine Lithium batteries? Are they worth the money, like, dislikes, ect? Thanks
02-17-2021, 08:11 AM #2
You might also check on bassboatcentral for feedback. Good luck.
Bass man thanked for this post
02-17-2021, 10:11 AM #3Member
- Aug 2017
- Wisconsin
- 33
- 22
Shh actually I did there too. Evidently they haven’t been around very long. Thanks
02-17-2021, 10:39 AM #4
What are you looking for in lithium battery , weight, cranking, storage capacity??? I have an Altroinics and it it 5yrs old and still going strong. I was was looking for weight savings mostly but all crank and storage specs were as good or better then anyone else's. I run 9amp system on 2.5 efi race set up and have never had issue. It actually cranked motor over no issue at 240psi compression where as had to go 24 volt with oddesy lead acid. Check out website and I see if they have what you are looking for. I am dealer and will sell to S&F members at cost.
David - WI, Bass man thanked for this postDavid - WI, rgsauger liked this post
02-17-2021, 11:12 AM #55000 RPM
- Feb 2010
- wisconsin
- 475
- 32
- 21
- 117
- 168
240psi eh?????? lol
Jerry's a straight up good guy to buy from so if your looking for some battery's he's got the information.
97 TWISTER liked this post
02-17-2021, 12:08 PM #6
Ok 240ish can't give up real number lol
02-17-2021, 01:56 PM #75000 RPM
- Feb 2010
- wisconsin
- 475
- 32
- 21
- 117
- 168
lol, i know who to ask
02-17-2021, 05:21 PM #8Member
- Aug 2017
- Wisconsin
- 33
- 22
Yes was looking for CCA as well as lighter. They have a 36v the size of 1 battery at half the weight.
I looked at your site they don’t appear to have a 12v battery with enough amp hours. Thanks 97 Twister
02-18-2021, 08:07 AM #9
I just got Dakota LI battery 24 volt BUT they are not for cranking, just for trolling motor only. 31 lbs and took the place of my 2 60lb Intrestates
Bass man liked this post
02-18-2021, 08:55 AM #10
These batteries look promising, especially with a 5 year warranty, and they’re made in the U.S. as well.
They don’t publish much in the way of specs though, other than CCA, reserve power and weight, although I guess those things, along with the group number are sufficient to select the battery you need.
interestingly, they’re quite a bit heavier than other lithium batteries on the market.
Here’s what I just got for my STV project:
https://4xspower.com/shop/li-series/...eries/li-s975/
1440 CA from a 10lb battery is crazy. Not much reserve power though, which is fine, since I’ll just be using the boat for drag racing.
02-18-2021, 10:54 AM #11
It is unlikely they are made in the US. May be assembled here but China does most all the lithium processing
for the world. The US only has 1 small LI mine.
02-24-2021, 04:21 PM #12
Pm sent
19 bullet
82 v king
84 v king
93 stv pro comp
07 venom
80 gt20
93 v-21
89 stv procomp
97 xr 2001
89 stv pro comp
82 17 action marine
99 action craft flats boat
88 xr2002
90 Stv pro comp
10 mirage 1/4 master
98 mirage 1/4master
02-24-2021, 04:22 PM #13
02-26-2021, 09:09 PM #146000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
TALK about crazy, 580ca from a 2.2 lb lith. cranks my 2.5, going on yr no. 3. you could run 2, @ 5 lbs.
02-27-2021, 09:31 AM #156000 RPM
- Nov 2006
- 1,496
- 13
- 130
- 70
- 626
- 35 Post(s)
anybody here using lithium batteries on there boat ?
By frontline in forum General Boating DiscussionReplies: 13Last Post: 03-31-2015, 06:49 AM -
Monster marine email address
By jcf1 in forum Props, Setup, and RiggingReplies: 0Last Post: 08-26-2013, 07:46 AM -
monster marine store
By hydrostream1 in forum General Boating DiscussionReplies: 8Last Post: 09-29-2008, 07:55 AM -
Marine Batteries: What's good and what to avoid?
By dashrockwell in forum General Boating DiscussionReplies: 25Last Post: 01-20-2005, 11:45 AM
