Page 14 of 26 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 196 to 210 of 385
  1. #196
    That's a slick install....
    Jun 2018
    Floating around
    Battery tray done. Foot pedal base set in core bond as well as the seat boxes. This is the end of fabrication now it’s all about refinishing which will start with gel coating the inside and the we will bond the cap to the hull.
ID:	497681 Click image for larger version.
  3. Likes tnelsmn liked this post
  4. #198
    Minneapolis MN
    Do you have a way to weigh the hull when you're finished? Our builds are very similar and I would be curious to see what the weight savings of the coosa is over marine plywood. If I ever build another one I plan to use coosa throughout.
  5. #199
    Jun 2018
    Floating around
    Im going to weigh it somehow, i'll figure it out. I like the coosa its been nice to work with aside from the extreme itchy factor. I got a flake that landed on my nose I didnt initially notice and I rubbed it in and it made a nasty bleeding spot for a couple weeks lol.
    Tony Ive been reviewing your build thread again as we are getting to the refinishing stage and I notice what looks like Nav light wiring under the deck but I dont see any Nav lights on your hull. What did you use if any? Got pics?
  6. #200
    Jun 2018
    Floating around
    Glassed in the seat boxes with two layers of 1708 above and two layers below the seat pad. One layer tied into the deck with csm tailing. We think one layer will be enough to hold the seat boxes in, anyone think different? We also laid one layer of 1708 over the foot throttle mount. The white material is mekp activated core bond I believe it’s called B72 and it is working great under the vinylester so if anyone is worried about core bond and vinyester this is the stuff to use. Wish I knew this before using the benzo hardened green core bond that apparently has some issues with curing under vinylester although I never did try so maybe that’s fine too? Dunno.
    also added a pic of the finished battery tray with corebond levelling trick. Certainly sped this process all up and fills wayyyyy better than thickened cabosil resin. It’s super light too.
ID:	497725 Click image for larger version.
ID:	497728 Click image for larger version.
ID:	497726 Click image for larger version.
  7. #201
    Mar 2004
    Brooklyn Park, MN
    I am going to weigh mine as well once I get the motor off and get ready to finally finish mine and paint the floor. Will be interesting to see the difference between all three. Anyway, one layer should be good for seat boxes and mount pads
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  8. Thanks LakeFever thanked for this post
    Likes LakeFever, tnelsmn liked this post
  9. #202
    Minneapolis MN
    Lake, I don't have a decent picture with the lights on, but I do have nav lights on the bow. They're LED strips that are mounted to the underside of the rub rail. I drilled a small have through the hull just under the rail and sealed it with 4200. You really can't see them during the day, but they're very bright when running at night. This picture is not where they were mounted. I went a little further back, but you get the idea.
    Attached Thumbnails Attached Thumbnails 62136995757__DB62DB9B-0B79-4289-91DD-248305683228.jpg
  10. Thanks LakeFever thanked for this post
    Likes LakeFever liked this post
  11. #203
    Lindenhurst, NY
ID:	497790Click image for larger version.
    transom light (upside down) and bow lights under railings
  12. Thanks LakeFever thanked for this post
  13. #204
    Jun 2018
    Floating around
    Cool! I’m definitely looking for a sleeker look than the factory deal.
    today we very lightly sanded the interior nubs and the edges of the exposed lays and hit the whole interior with tooling gel. My thinking was to use tooling gel first to help fill some of the roughness of the 1708 because we didn’t really sand it. Just a quick hit with 80 and even that ate up a lot of sanding disks. Tomorrow we are going to hit it with waxed gel and call it done. If there is time we will bond the cap down but I doubt we will do that tomorrow because I will need to lay on the gel to bond in the knees so the gel will have to be really cured up well. I’m not sure what to expect this is our first gel coat experience. Much to our surprise ( maybe I’m showing my age here ) but rolling the gel out was actually quite easy, and quite familiar. If anyone has ever painted with old lead base oil paint when it’s a little cold out? That’s exactly how gel coat feels lol.
ID:	497795 Click image for larger version.
ID:	497796 Click image for larger version.
  14. Likes tnelsmn, cameronj, Hippie459MN liked this post
  15. #205
    Minneapolis MN
    Heck yeah!!! Looks killer!
  16. Thanks LakeFever thanked for this post
  17. #206
    Jun 2018
    Floating around
    Thanks man your build thread was the main road map and we wouldn’t have done nearly as good a job without it
    I forgot to mention we also gave it a good wipe down with acetone about an hour before we gel’d it. We played with tinting the gel a bit, so the gel is very light grey. Tomorrow with the waxed gel we are going to darken it up some more because I have serious light sensitivity and find white boats hard to be in. We are also going to try and do some sort of fleck finish with a darker grey again. Fingers crossed I’ll update after we get that done
  18. Likes tnelsmn liked this post
  19. #207
    Jun 2018
    Floating around
    When we gel’d it yesterday we noticed the stitching in the 1708 would take up a little gel and swell. No big deal but it did leave a slightly sharp rough feel that the wife and daughter won’t like so we gently ran a small sanding pad with 80 over it today. It cleaned up quick although plugged the paper every ten strokes lol. Then we hit it with waxed gel tinted to a decent medium gray and did some fleck with slightly darker grey. We’re pleased with it.
    Next stop is bonding the cap
ID:	497839 Click image for larger version.
ID:	497840 Click image for larger version.
  20. Likes tnelsmn, Hippie459MN, 89LASER, MrBoatYard liked this post
  21. #208
    Mar 2004
    Brooklyn Park, MN
    Looks soooo nice when brand new! This thing is going to be one nice ride just like Tony's. Brand new boats, fantastic. Mine, more of a beater race boat that looks good from 50 feet!
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  22. Thanks LakeFever thanked for this post
  23. #209
    Jun 2018
    Floating around
    Thanks Rj, ya it’s basically new aside from the skin. It’s very satisfying work which was a pleasant surprise. My first go with fiberglass, I think we could cut the time to do this in half if we ever do another one. It took a while to get a feel for it, especially with the short time window to work with catalyzed resin. I learned a ton along the way. Good times
  24. Likes tnelsmn, rjdubiel, Hippie459MN liked this post
  25. #210
    Jun 2018
    Floating around
    Been busy lately but today we managed to get the deck bonded to the hull. We set the stringers into the knees using core bond and we ran black 5200 down the lip and clamped it. It took exactly one tube per side. I’m wondering how long I should leave it clamped though? Not sure how long that 5200 takes to cure.
ID:	498119 Click image for larger version.
ID:	498120 Click image for larger version.
ID:	498121 Click image for larger version.
ID:	498122 Click image for larger version.
ID:	498123 Click image for larger version.
  26. Likes 89LASER, rjdubiel, tnelsmn liked this post
  1. 1979 Hydrostream Viking
    By nelson edens in forum Hulls up to 20'
    Last Post: 08-17-2020, 07:38 AM
  2. 1979 Hydrostream Viking restore thread
    By roadkill636 in forum Fiberglass and Composites Discussion
    Last Post: 02-22-2020, 07:24 AM
  3. 1979 checlmate eluder w 1979 merc 175
    Last Post: 06-10-2012, 02:28 PM
  4. 1979 hydrostream viking setback
    By brianbgboy in forum Technical Discussion
    Last Post: 06-29-2004, 11:00 PM
