Results 1 to 2 of 2
Thread: PROPer Setup
    Jun 2018
    Tequesta
    PROPer Setup
    Refitting a 1972 16’ Powercraft. Rigging a 2001 Mercury 125 2 stroke 25” shaft. Will bolt it direct to the transom. This is a V hull no pad. Appreciate suggestions for prop and engine mountingClick image for larger version.
ID:	482524Click image for larger version.
ID:	482525Click image for larger version.
    Jan 2020
    Pinole, Ca
    I assume the transom is a 25" transom to match the motor?
    Is the gearcase side pickup or has it been coned?
    What weight load will the boat see and what kind of water/where will you be running?
    I we are talking a stock lower then you should be able to mount the motor with the bolts in the bottom hole (highest) and then plug the top 4 water pickup holes on each side of the lower. Every hull is different in how it kicks water back, but I rigged a 16' V last year with no setback and I held water pressure fine and had no trouble with porpoising with the motor all the way up and the 4 holes plugged on the lower.
    I assume you want to run stainless? If not, an aluminum 19p would be a good place to start.
    Stainless I would be looking for a through-hub cleaver or semi cleaver if you can find one. Check out Ron Hill props, not sure if he makes them for your gearcase or not. Below is a pic of what I am referring to. If you can't find a through-hub cleaver then I would look at Yamaha props cause they have a straighter trailing edge than Mercs and I've found that non pad V hull like that.
  1. proper setup for a 1987 hydrostream vegas to go over 80 mph
    By Steve Collette in forum Props, Setup, and Rigging
    Last Post: 10-07-2014, 09:22 AM
  2. Mercury Tech: STV euro/ 2.5 260 merc proper setup
    By strokinstroker in forum Technical Discussion
    Last Post: 04-13-2010, 10:03 PM
  3. What's the proper way?
    By BenKeith in forum General Boating Discussion
    Last Post: 12-25-2003, 11:31 AM
  4. What's the proper name
    By MarkHP in forum Technical Discussion
    Last Post: 09-02-2003, 07:07 PM
  5. Proper Set Up
    By owens repair 52 in forum Props, Setup, and Rigging
    Last Post: 09-05-2002, 07:26 AM
