Results 1 to 2 of 2
02-14-2021, 12:58 PM #1
Need help with sportmaster part number's
I've been on mercury marine's parts site and the diagram/part list isn't matching up.
What I need is the part number for the three studs in the front of the sportmaster lower for a 15'' offshore mid.
and
The rear mounting bolt for a 15'' offshore mid?
I will need the lock nuts and washers also.
If you have the parts that would be helpful also.
Thanks in advance.
Stoney
02-17-2021, 03:24 PM #2
Are those studs different that the fishin ones? I have a 15 offshore sporty, the 2 different CLEs and a couple fishin lowers on my bench and they all look like they have the same studs. Which part numbers are you coming up with? It is also possible that the sporty I have has had different studs put in it...I know the guy who owns it keeps cracking the front of his mid around those 3 studs...
I see the front 3 studs are 16-59579
I see the nuts for those are 11-859116
The bolt under the trim tab/anode in the back is appearing as an Allen and p/n 10-30206
Mercury Tech: Part number ?? sportmaster 2.5 280 hp.Merc
By Salmavuro in forum Technical DiscussionReplies: 0Last Post: 09-03-2019, 08:38 AM -
Part Number of a Sportmaster Gearcase
By Beak Boater in forum Technical DiscussionReplies: 1Last Post: 07-22-2019, 05:16 AM -
Mercury Tech: sportmaster carrier part number
By speedinstream in forum Technical DiscussionReplies: 7Last Post: 04-16-2014, 05:38 PM -
Part Number for Flo-Tor Hub on 2.5l Fat Shaft sportmaster?
By tony97gt in forum General Boating DiscussionReplies: 9Last Post: 06-01-2013, 10:00 AM -
Mercury Sportmaster Bearing Part Number?
By steve in forum Technical DiscussionReplies: 1Last Post: 01-15-2004, 06:14 PM
