Results 1 to 8 of 8
Thread: VST Removal
02-13-2021, 09:08 PM #15000 RPM
- Mar 2018
- NJ
- 196
- 10
VST Removal
I just removed my VST on my modified 225 Promax. I installed a Bosch remote pump(mod-580 254 957)with a 100 micron filter before the pump,then the supply line runs to the factory Canister filter then to manifold. Installed a Gold regulator with this, is this too much filtering. Thank you
02-13-2021, 10:17 PM #2
Big no on pressurizing the canister filter. Those paper element filters should be on the suction side only.
phillnjack thanked for this posttux974, phillnjack liked this post
02-14-2021, 08:07 AM #35000 RPM
- Mar 2018
- NJ
- 196
- 10
Thank you Capt--I Appreciate the help..
02-14-2021, 02:59 PM #4
I’m going to rebuild my 2.5 efi soon. Is it wise to ditch the VST?
02-14-2021, 06:35 PM #55000 RPM
- Mar 2018
- NJ
- 196
- 10
Hi-LakeFever--This is my first ditching of VST. I decided to go this way because of running a modified powerhead. I am sure there are Good Tech Guys on here to give you true benefits of it.
LakeFever thanked for this post
02-14-2021, 08:28 PM #6
Here's a pic of my vst delete
02-14-2021, 08:44 PM #75000 RPM
- Mar 2018
- NJ
- 196
- 10
Roadkill--Thanks for the picture. Question where did you connect the vacuum line off the VST with the check valve in it. Thank you
02-15-2021, 06:27 PM #85000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
.. Take it off
VRO removal
By skatermike24 in forum Technical DiscussionReplies: 6Last Post: 12-07-2007, 09:01 AM -
Tap Removal Man - N. Ca
By 2fast4mom in forum Technical DiscussionReplies: 0Last Post: 04-20-2004, 10:14 PM -
VRO Removal
By delawarerick in forum Technical DiscussionReplies: 1Last Post: 04-18-2004, 08:41 AM -
VRO Removal----HELP!!!!!!!!!!!!!
By A.J. Pastwa in forum Technical DiscussionReplies: 3Last Post: 01-06-2003, 12:35 PM -
Omc VRO Removal
By delawarerick in forum Outboard and Racing HistoryReplies: 1Last Post: 06-14-2002, 09:31 AM
