Results 31 to 45 of 49
  1. #31
    May 2014
    Livingston, Louisiana
    Hey, Canuckr, I just added some degree measurements for a 300 I have in the shop in my HPDI thread if ya want to look at them. I’ve only got degree measurements as of now, but I can mic em if ya need me to
  2. #32
    Aug 2019
    Palmharbor
    Take the 3.4 hpdi swap electronics from ox66 250 add 225 heads add the oxygen sensor to the 3.4 block 356hp all day smoothe running torque galore and reliable just make sure there are no corners all smooth Radius into the window piston and Bottem entry’s will make fuel stay mixed more power an economy
  3. Thanks canuckr thanked for this post
    Likes Capt.Insane-o, panther150, Garth91 liked this post
  4. #33
    Jun 2014
    Petawawa, ON
    Quote Originally Posted by MrG View Post
    Take the 3.4 and ox66 250 ink 225 heads add the oxygen sensor to the block 356hp all day smoothe running torque galore and reliable just make sure there are no corners all smooth Radius into the window piston and Bottem entry’s will make fuel stay mixed more power an economy
    Can you elaborate a bit more on the first sentence. Lost me a bit.
    My block isn't machined for the 02 sensor. Casting is there but wasn't machined for it.
  5. #34
    Aug 2019
    Palmharbor
    You have to machine the block for Oxygen sensor and the fuel injection from a 250
  6. #35
    Nov 2009
    hardyville va
    Quote Originally Posted by canuckr View Post
    I have done a HPDI to EFI operating systems swap. The exhaust cover needs to be swapped to bolt the electronics. I was able to fat file the O2 boss and drill and tap the bolt holes, as well as the hole into the cylinder for the sensor. I also added the third low pressure fuel pump to the block the same way. You use the HPDI flywheel and starter. It makes a beast of a reliable motor, from a hand grenade POS.
  7. Likes MattGreen liked this post
  8. #36
    Chaz = wunderin , when "cali" wuz gonna set the record skrate ...
  9. #37
    Built a number of these out of parts most people throw away. Probably one of the best kept secrets out there.
  10. Thanks panther150 thanked for this post
  11. #38
    Jun 2014
    Petawawa, ON
    Well if you find enough throw away parts to build another one let me know.
  12. #39
    Nov 2009
    hardyville va
    I probably have most of the stuff.
  13. #40
    Jun 2014
    Petawawa, ON
    Quote Originally Posted by cali kid View Post
    PM Sent.
    And for anyone else that might know. Looking for pics and dimensions of the hole through the block for the 02 sensor
  14. #41
    Aug 2019
    Palmharbor
    For the most part it’s a 1/8 hole with a step up the insert that slides into is of a 8 mill the gasket kit is a good template to start with but I’d get all the parts first and mic the insert valve they are a beast
  15. #42
    Nov 2009
    hardyville va
    I did not use the insert.
  16. #43
    Aug 2019
    Palmharbor
    Your better off just adding the ox66 fuel system to the 3.4 and making the oxy sensor provisions clean up the casting alignment , radius the Bottem windows and taking out the extra hanging in the exhaust window it just brings it to the max port it was designed for max power !! This set up will make 356 Hp all day long on stock efi parts now you can crank up the fuel pressure and slot the timing mount and 91 fuel 400 Hp gets close… Every Yamaha made has Always been detuned from factory to live on low quality fuel !! Id do 2 major additions before cranking it up from factory efi 1 add piro ports in exhaust and a Johnson enrichment solenoid to safeguard lean out / I’ve put many on 2.5 mercury to save them after chopping the throttles and lean wipe out at Hi rpm .. hope you get that old school rules sticker on the cowling when your all done long live the 2 stroke power (just a thought 600 Hp Merc 70,000.00) will only last 7 years before exhaust eats out the block …
  17. #44
    Jul 2009
    Crawfordville fl
    Sorry to high jack this tread. But I’m just wondering when converting from hpdi to 0x66 operating system. Did u use the hpdi oil pump setup , or cap off the oil lines to hpdi pump and use 0x66?
    Nitrous is like a slut. u wanna hit it but you know there will be consequences.
  18. #45
    Aug 2019
    Palmharbor
    On that port work I’ve always brought the exhaust ports to the casting and always seemed to have a very powerful blueprint to go by as far as transfers make them square with out changing port entry angle but mostly found it’s the feeds for the ports that are limiting power Attachment 514350Attachment 514351
  1. port timing
    By xskeetshooter in forum Technical Discussion
    Last Post: 12-24-2014, 07:05 PM
  2. Mercury Tech: port timing
    By MercMyles in forum Technical Discussion
    Last Post: 12-18-2009, 10:07 PM
  3. OMC Tech: Port Timing
    By L A streaming in forum Technical Discussion
    Last Post: 04-15-2009, 10:31 AM
  4. V4 Port Timing
    By PJB in forum Technical Discussion
    Last Post: 02-14-2003, 09:28 AM
