Results 1 to 15 of 18
    May 2006
    Mercuryville, WI
    Mercury 2.4L 200hp
    For Sale: '89 Mercury 2.4L 200HP (no lower unit) – engine needs rebuild, comes with extras…
    Price: $650…Includes complete powerhead, cowls, mid-section and spare (new) OEM plug wire. (Note this engine does not have a lower unit but one is available if needed for additional cost…see below). Motor being sold in as-is condition. Currently bolted to an outboard shipping pallet. Shipping cost additional.
    For Sale: Early 90’s Mariner Magnum 2.5L lower unit. This lower was removed from an outboard that was in good working condition. This was a fresh water motor used in WI. (see pictures below)
    Price: $475… for lower unit in as-is condition. Shipping cost additional.
    *Note: Motor and lower unit can be sold together for $1,125 or sold separately as listed above but motor needs to sell first. Located in central WI.
    Mercury 2.4L 200HP engine details:
    This engine originally had a lower unit with a low water pick-up. The engine sucked up sand, plugged the bottom water jackets on the block and overheated. It was not at high speed nor was the engine completely locked up. Cylinder bores #5 & #6 on the bottom were scored. It's a freshwater motor from WI so no salt water corrosion to the internals. The water cooled voltage regulator had only a few hours of run time when I overheated the engine so it’s like new. That part alone is worth almost half of what I’m asking for the powerhead & mid-section. The stamping on top of the carbs looks like 157-155 if that makes sense to anyone in the know on Mercury carbs. The bucket style cowling is in great condition. It’s missing a plastic cover that goes over the lower front latch but functions fine without it. It has additional blue pin stripe added that matched the boat but can be removed easily (non-painted). I’m including a new- in-the-package Mercury plug wire to go with the engine.
    The motor appears to be stock and never rebuilt in the past. At a minimum, it will need 2 or 3 steel sleeves, pistons and one or both heads replaced. Pictures show scoring to the cylinder walls and head domes on 5 & 6. My plans were to re-sleeve all six cylinders, install a different set of heads and have fun…but my boating plans have changed and I no longer have a use for this motor. Once rebuilt this should make a nice 200HP for a good price…or use it for parts. The outboard is bolted to a factory wooden Mercury outboard pallet and can be shipped via freight at buyer’s expense. The motor is currently located in central WI. I can meet within a 2 hour radius to help with delivery if needed.
    Attached Thumbnails Attached Thumbnails 2.4L with cowl on.jpg   2.4L with cowl on 2.jpg   IMG_20130622_103840_415.jpg   20200904_210802.jpg   20200904_210754.jpg
    May 2006
    Mercuryville, WI
    Attachment 482461
    May 2006
    Mercuryville, WI
    Bump
    Mar 2004
    Brooklyn Park, MN
    your PM's are full.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    May 2006
    Mercuryville, WI
    Cleaned up the inbox
    WoodForest TX
    Message sent
    May 2006
    Mercuryville, WI
    Motor and lower unit are still available. Once rebuilt it will make a nice 200 HP for someone.
    Nov 2018
    lancaster, Pa
    is lower 20" or 25"?
    May 2006
    Mercuryville, WI
    Quote Originally Posted by Asstracker View Post
    It's a 20".
  10. Likes Asstracker liked this post
  11. #10
    Mar 2021
    Roscoe Il
    Where are you located
  12. #11
    May 2006
    Mercuryville, WI
    Quote Originally Posted by Swtzerson View Post
    PM Sent
  13. #12
    USA
    hdello i will buy this engine ph please
  14. #13
    May 2010
    Wilmington, NC
    still available?
  15. #14
    May 2006
    Mercuryville, WI
    Yes.
  16. #15
    Sep 2008
    charlestown, ri
    nice clean motor, but 3 sleeves yikes! thats over $1000 in machine work alone. is it standard bore? hard to see but scoring looks like it would clean up nice with .030'' over? or are there deep gouges we cant see?
  1. Wtb mercury 200hp efi 98-99s
    By Risk Manuel in forum Outboard Engines
    Last Post: 09-21-2018, 10:31 PM
  2. 2.4 L Mercury 200hp
    By goday32 in forum Technical Discussion
    Last Post: 08-24-2010, 07:58 PM
  3. How heavy is my 200hp Mercury?
    By Air Dog in forum General Boating Discussion
    Last Post: 01-12-2005, 01:21 PM
