Results 1 to 5 of 5
    May 2016
    Upper Potomac River
    Hydraulic Steering Cable Length on a Viper
    Hey Folks,
    I'd like to install hydraulic steering on my Viper before spring. Anyone have any idea how long the hoses should be? I have a seastar pro helm and tournament series ram. I'm planning to have the lines come up through the center of the splash well using some sort of through connectors. I already have some short hoses to go from the well to the ram... I was thinking of routing the cables around the passenger side of the boat.
    Any thoughts?
    Southside, Al.
    First thought is - get out a tape measure ------------------------
  3. Likes rock liked this post
    May 2016
    Upper Potomac River
    Haha, well of course... was just looking to see if anyone had done it before (I'm sure many times) I would think the shorter the better... I may put 90* elbows at the helm to help shorten the run...
    Minneapolis MN
    If you're going through the center of the splash well SeaStar makes a decent looking bulkhead. It is what I'm running on mine. You would just spec that extra part number when you order the hoses. It's not something you can add later.
    Sep 2017
    ontario
    As stated - measure twice and the bulk head fittings are a nice touch . They Seastar have a great support line - I call it Rapid Service - he - can't recall name is excellent .
    Don't forget order fluid and fill kit .
    I know your asking for an exact length but I can help you there - just measure and 1500 psi lines are not much more - bulkhead fittings - singles or double and usual I believe for those lines is 2 ft . Call em once you have done some homework and gone through the catalog and fittings page . Easy
  1. hydrostream viper cable length
    By nohasslekindaguy in forum Props, Setup, and Rigging
    Last Post: 06-14-2017, 09:26 AM
  2. Hydrostream Viper Throttle Cable length
    By digitish in forum Props, Setup, and Rigging
    Last Post: 07-07-2015, 07:25 AM
  3. What length steering cable for a Viper?
    By bearclaw in forum Technical Discussion
    Last Post: 07-19-2009, 06:16 PM
  4. Hydraulic or Cable Steering on Viper??? Need Advise Quick!!!
    By mragu in forum General Boating Discussion
    Last Post: 08-07-2008, 02:19 PM
  5. 22 Velocity hydraulic cable length?
    By tmull44 in forum Technical Discussion
    Last Post: 04-17-2006, 07:57 AM
