Results 16 to 30 of 38
    Jul 2002
    Las Vegas, NV
    https://youtu.be/PZm11iP0EUU
    yet another perfect example why bobs plates are junk.
    I ran the Bob's plates on my Scarab with Monty V8's and never had an issue after 10 years. Seems like given the amount of movement, and all in one direction, I'd venture to guess that one or both of the jackplate to transom bolts on the port side were loose, broken or gone.
    Keith-
  2. #17
    Quote Originally Posted by STV_Keith View Post
    I could almost walk there and no thanks....
    Gordon got a good vid of lighter motors 5-6yrs ago. Same issue and it was not pretty.
    https://youtu.be/BQaM4rcyCzA
  3. #18
    Maybe on a kneel down with a tiny prop....Doug and I get a few things out of the way we will get to it. We are on a tin boat mission right now so when those are done we will see. I've been in a lot of Honda gearcases and don't see a problem there. The metallurgy of the gears is excellent, and the propshafts are very forgiving. Plus they are basically parts binned from their automotive and the tuners have been modding those motors for 20 years.
    similar to the Yamaha nizzpro stuff well powerheads atleast. The nizzpro guys were at the local dealer Gause built dave said they never had a failure rod piston nothing. The crank and valve train on the 4.2 are over engendered which is good when your adding 175hp to a production f300.
    just went through two 100hr 2019 f300 cases for an insurance claim and they are stout but I see why nizzpro makes the big shafts carriers etc. the weak points are obvious. Surprisingly similar to the sportys also.
  4. Likes rgsauger liked this post
  5. #19
    Jul 2002
    Las Vegas, NV
    To each their own. Looking at the video it looks like the plates are twisting laterally in their slide channels. There are bolts that hold the two side extrusions together and I can't see the plates twisting unless those aren't tight enough, not allowing the plates room to move.
    Keith-
  6. #20
    Pretty sure Those are the redesigned extreme plates they were brand new on a brand new boat. Gordon assembled the engines and rigged the boat you know his attention to detail. They all move nature of their design bobs just move a lot. This is Probably why they just came out with a completely new design I have no experience with the new billet design but they obviously knew there product was lacking.
  7. #21
    Oct 2010
    Harrisburg,Pa
    Damn no thank you
  8. #22
    Jun 2002
    Winter Haven Fl.
    Quote Originally Posted by Da Bull View Post
    Honda is not interested in a high performance outboard so they more than likely asked or even paid the guys to stay away from that. If Honda wanted to I`m sure they could take the high performance outboard world by storm.
    Was a Honda dealer for35 years and unfortunately years back their attorneys ended up with too much input in the R&D department.
  9. Likes baja200merk, JR IN JAX liked this post
  10. #23
    Moline,Ill
  11. Likes baja200merk liked this post
  12. #24
    Shreveport, La.
    Did ya`ll notice that even though the jack plate is junk that the transom on that Rapid Craft wasn`t even scratched! Rappid Craft boats were build very strong.
  13. #25
    Jul 2002
    Las Vegas, NV
    Quote Originally Posted by BUZZIN' DOZEN View Post
    Another case where the top bolt is missing. I'd expect a failure when the plate is not properly held in place anymore.
    Keith-
  14. #26
    So you think Bob’s ships the plate with a bolt missing or the person rigging it doesn’t tighten them? Everyone knows why they break or flop around including bobs hence 2 total redesigns (copy of torrente cough cough)
    I’ll text Gordon to check but I’m 99% sure the extreme series flopping around in his video are rated for motors 200# heavier than the 16” 3.4 250HOs in the video.
  15. #27
    FLA
    The Bobs plates on the RJR that Gordon was running kept them from running any faster . I have a Bobs on 2 of my boats and it does move some and all the bolts are in and tight and 1 has less than 15 hours total . The only plate that anyone has run on the super stock 32s were Porta Plates and they got banned guess they were to good .
    24 Twister
  16. #28
    This was actually a feature I was working on with Dale Wagner, the guy that built the turbo. But COVID hit and put that on hold.
  17. #29
    Jul 2002
    Las Vegas, NV
    I think a mounting bolt coming out will cause the plate to twist and deflect enough to allow it to break. I suppose that could be considered the riggers fault, sure.
    We all get your opinion here. Bob's sucks. Cool story.
    Keith-
  18. #30
    In true SnF winter fashion sh*t goes manure pile.
  1. 95 Honda 2 door Coupe EG turbo 5 speed $ 3000
    By Eric T in forum Non-Marine Items
    Last Post: 04-09-2016, 05:27 PM
  2. turbo 4 stroke honda for smaller boat?
    By aaron78viper in forum General Boating Discussion
    Last Post: 08-19-2015, 08:52 PM
  3. Turbo charged Honda 4 stroke
    By gsmarine239 in forum Technical Discussion
    Last Post: 08-19-2015, 07:33 PM
  4. Honda Bf 225 twin turbo??
    By Seacenter in forum Technical Discussion
    Last Post: 03-03-2005, 08:27 PM
  5. Honda blackbird turbo
    By racerx in forum Other Motorsports
    Last Post: 02-16-2003, 12:32 AM
