Results 1 to 6 of 6
    Jun 2004
    port st. lucie, fl
    Driveshafts for the ssm
    So I have a ssm, square back cavitation plate, no shim inspection port. It came to me with a broken driveshaft, and a new driveshaft. I got the driveshaft installed (old one and new one looked and measured identical, but when I went to install the upper gearset, the gear will not go over the driveshaft splines. Looking at the splines, they come to a point, whereas the broken driveshaft splines are square at the tip. Od is slightly larger also on the splines area. So I assume I installed an mc1 driveshaft?? Will the #4 or 6 driveshaft fit this gearcase? It's going on our t2x. Or if someone has a good used driveshaft that would be great. Thanks! Click image for larger version.
    Dec 2001
    Wellllll I see your problem.......Thats an OMC drive shaft. You could never put in a MC1 they are a Bit larger. Does it have a flat or slot for the water pump?
    Jun 2004
    port st. lucie, fl
    Flat spot, and correct spline for mercury. I pulled it back apart last night, and compared both, it appears that one machining step was left out of the new driveshaft, everything else measures the same, spline area is .060" larger in diameter. It's going in the lathe today.
    Get your wife to look at it for you, your glasses aren't strong enough
  5. Likes mrcrsr liked this post
    Dec 2001
    Yea.... I see the Flat.........Just was thinking it might have been a early one..... w/slot......don't know if they made em with slots..........
  7. Likes mrcrsr liked this post
    Apr 2013
    pa.
    I had same problem, flat gears would not fit on splines, found out after I got prop shaft , gears installed, shimmed, etc., I was putting one together with parts from all over the place, thought everything was interchangeable, maybe different vendors made them from different years, had to take it all apart and turn splines down a bit, then it fit, lesson learned, dry fit everything, assume nothing...
  9. Likes crazy horse liked this post
  1. I need driveshafts
    By Bruster in forum Parts Wanted
    Last Post: 07-06-2015, 12:15 PM
  2. 2.5l/3.0l driveshafts...
    By STV_Keith in forum Technical Discussion
    Last Post: 10-05-2006, 09:08 AM
