Page 3 of 3 FirstFirst 1 2 3
Results 31 to 35 of 35
  1. #31
    Pekin, IL
    Quote Originally Posted by JAFFA View Post
    44104A 8
    15 tooth pinion
    28 tooth forward gear (ratcheting type)
    Merc V6 200
    Think I got the right numbers
    Closest thing I could find was a 44104/2. Don't know if that is even close. Was also no pinion to match. Sorry.
    Rock
    Team Junk
  2. #32
    Feb 2003
    Auckland - New zealand
    Yea I think that's the one, probably the pinion is 44104/1 and reverse /3, I'll have another look at my pinion but I think I need both
    Peter Thomas
  3. #33
    Pekin, IL
    I do not have a pinion with # even similar to that or a reverse gear. Are you sure about the 15 tooth. That would be less than 2:1. The pinions I have are 13 tooth.
    Rock
    Team Junk
  4. #34
    Pekin, IL
    Lower unit stuff posted under lower units in classified.
    Rock
    Team Junk
  5. #35
    Oakville, ON
    I got my engine yesterday. All went well. Thanks Rock
  6. Thanks rock thanked for this post
  1. Mid 90's merc 150 xr6 weight reduction?
    By Chingadera in forum Technical Discussion
    Last Post: 04-30-2017, 08:07 AM
  2. Drag Reduction Using Primer?
    By LSaupe in forum Technical Discussion
    Last Post: 01-16-2010, 05:23 PM
  3. Drag Reduction Research?
    Last Post: 01-08-2010, 09:16 AM
  4. ET reduction w/ Steckbauer/XR6
    By JAGPILOT in forum Technical Discussion
    Last Post: 12-06-2002, 08:10 PM
