Results 1 to 11 of 11
Thread: Promax Question
01-27-2021, 08:03 AM #15000 RPM
- Mar 2018
- NJ
- 196
- 10
Promax Question
I just picked up a fresh rebuilt (2 hours on it)225 promax with 260 porting,the heads are cut to 32cc. My question-is this too much compression with 93 octane. The motor will be on a fish/Ski boat about 1500 lbs--26/4 blade Trophy plus prop. Thank you
01-27-2021, 10:32 AM #26000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
Youll need to do a comp. test. my225 has150lbs with 32 cc heads, runs fine. your porting might change those specs. Thats alot of prop for 1500lbs, my 2 cts.
01-27-2021, 05:39 PM #35000 RPM
- Mar 2018
- NJ
- 196
- 10
Thank You for the reply. Yes soon as mount it will do compression test. What timing are you running on your motor-we have 93 octane here hoping than enough. Thank You
01-27-2021, 06:33 PM #4
Exhaust port height and head gasket thickness and bore size and ring gap will all affect the compression.
What is the porting measurements?
01-27-2021, 09:36 PM #55000 RPM
- Mar 2018
- NJ
- 196
- 10
I just got this powerhead 2 days again so i have no real specs yet. Exhaust chest is completely machined and polished that i can see,there is head studs on it also. It is a Mag Motor.
01-27-2021, 10:18 PM #6
Exhaust chest won't affect compression. And MAG mota aint got nutty to do with Promax.
01-27-2021, 10:35 PM #76000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
25* 93 works for me. you say MAG, meaning a mariner?
01-28-2021, 07:09 AM #85000 RPM
- Mar 2018
- NJ
- 196
- 10
No sorry--It is a powerhead built by Mag Machine Service. I am thinking i was going try 23/24 degrees with the weight of the boat. Thank you
01-31-2021, 11:57 AM #9
Just get a 5 gal of race fuel and bump the octane up a bit. You can't trust the fuel these days. Here is the site to convert octane. I use 110 race fuel to mix with, don't take much.
http://www.bazellracefuels.com/Calcs/OC1.htmLast edited by perfmarine1; 01-31-2021 at 11:59 AM.
01-31-2021, 12:19 PM #10
Just get a set of 34cc heads and run it, 32cc is a bit tight.
01-31-2021, 03:34 PM #115000 RPM
- Mar 2018
- NJ
- 196
- 10
Thank You Guys always appreciate the help and advice. I going to see if anyone would like to swap a set of stock Promax Natural Heads or 34/35cc heads for these 32s. These are Promax C-3 Natural heads in Great shape. Thank you
Promax question
By Steve G in forum Props, Setup, and RiggingReplies: 4Last Post: 08-05-2019, 01:50 AM -
225 promax question please
By smiley88 in forum Technical DiscussionReplies: 23Last Post: 02-14-2017, 10:40 PM -
225 Promax question
By cgates2193 in forum Technical DiscussionReplies: 8Last Post: 10-05-2012, 11:00 AM -
Promax question.
By SatisfAction in forum Technical DiscussionReplies: 5Last Post: 07-14-2008, 05:02 PM -
200 Promax w/ SVS and PCU question.
By Vicious in forum Technical DiscussionReplies: 6Last Post: 09-12-2005, 08:32 PM
