Results 1 to 10 of 10
01-25-2021, 05:58 AM #15000 RPM
- Jun 2018
- Orlando
- 100
- 15
- 9
- 67
- 41
250 EFI won't go into gear after impeller change
I dropped both lower units today, replaced impellers and put new props on both. Basically same procedure followed for both, so I thought. Port motor (1B043974) will not go into gear now, while starboard works fine. There's no resistance on the shifter for the port motor. I removed the cowling and can see the cable actuating the shift mechanism on the side of the powerhead, but nothing is happening down below. Regardless of shifter position the prop spins by hand with no resistance in either direction. I am assuming the upper shift shaft did not engage the coupler to the lower shift shaft when I reinstalled, and I just got lucky on the starboard side?
Just looking for some guidance on rectifying this. Port motor is a counter-rotating unit. Thanks!
01-25-2021, 06:06 AM #2
Yep I think you missed the splines when you installed it. Just drop it back down and bit and align and back in and you should be good.
22R
trivialpursuits thanked for this post
01-25-2021, 09:52 AM #35000 RPM
- Jun 2018
- Orlando
- 100
- 15
- 9
- 67
- 41
01-25-2021, 11:19 AM #4
i would remove the nuts and put a floor jack under the skeg and only drop enough to free the shift rod. On my 2.5 Merc XR6 I can manipulate the shift rod coming down from the P/H with my fingers then slowly raise the lower up into place. A helper helps alot but can be done solo if needed.
22R
trivialpursuits liked this post
01-25-2021, 03:21 PM #5
Don't lose the shaft coupler.
01-25-2021, 07:13 PM #6
Capt.Insane-o liked this post
01-25-2021, 07:53 PM #76000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
01-25-2021, 08:15 PM #85000 RPM
- Jun 2018
- Orlando
- 100
- 15
- 9
- 67
- 41
Nah, the coupler was there. But upper shift shaft not inserted into it. However, I dropped the coupler in the water when I removed the lower unit again today, so waiting on a replacement from ebay
01-25-2021, 08:25 PM #9
02-05-2021, 05:46 AM #105000 RPM
- Jun 2018
- Orlando
- 100
- 15
- 9
- 67
- 41
Followup for closure of thread: The upper shift shaft was in fact NOT engaged with the coupler to the lower shift shaft. Problem has been solved and it's shifting fine now.
gear case 1.62 gear change
By Bjorn08 in forum Technical DiscussionReplies: 5Last Post: 07-23-2013, 09:53 AM -
Sounds easy to change the impeller
By ronnyd8719 in forum Technical DiscussionReplies: 11Last Post: 06-29-2006, 01:10 PM -
gear change?
By Shawn L. in forum Technical DiscussionReplies: 1Last Post: 12-22-2005, 08:32 AM -
99 225 Pro Max gear case change out
By wrpowerstroke in forum Technical DiscussionReplies: 3Last Post: 09-16-2004, 08:20 PM -
Evinrude impeller change 175/200hp1977 how to?
By billyboy in forum Technical DiscussionReplies: 1Last Post: 09-16-2004, 06:09 PM
