Results 1 to 10 of 10
01-24-2021, 10:15 AM #1
Q about 300R fuel / water separator.
In the Mercury manual it mentions a "boat mounted" fuel-water separator.
Is anyone using a Racor type filter? And if yes... a 2-micron or 10-micron?\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
01-24-2021, 10:31 AM #2Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,644
- 606
- 923
- 1698
- 7146
- 3 Post(s)
Yes, I have one and I also got rid of the primer bulb after I did the initial start up. It fires instantly with the big lift pump. 10 micron filter-
01-24-2021, 10:53 AM #3
Yes I thought if they mentioned it in the owner's manual without any warnings like for the Opti I should have one. I got a few of those in the barn, gives me a project for the afternoon.
01-24-2021, 11:44 AM #4
If you have one with the WIF sensor I’d recommend it, as there’s a harness and input for it so you get the warning if water is present.
A problem is only a problem when viewed as a problem...
01-24-2021, 01:45 PM #5\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
01-25-2021, 06:48 AM #65000 RPM
- South Africa
- 576
- 31
01-25-2021, 06:58 AM #7\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
01-25-2021, 07:03 AM #85000 RPM
- Jan 2018
- Not a tourist in Forida anymore.
- 338
- 22
- 290
- 321
01-25-2021, 07:24 AM #9Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Biggest choke point in most fuel systems is the anti siphon pc in the fuel pickup. Filter is nothing compared to that one. Put a vac ga on your fuel line, and check it.
01-25-2021, 06:28 PM #10Supporting Member
- Apr 2003
- 6,644
- 606
- 923
- 1698
- 7146
- 3 Post(s)
Mercury Tech: Looks like water in fuel but no water in water separator. Confusing. Any ideas?
By Steve2ManyBoats in forum Technical DiscussionReplies: 6Last Post: 07-23-2014, 02:05 PM -
Fuel in water separator -- how much is too much?
By Stoker1 in forum Technical DiscussionReplies: 14Last Post: 11-04-2013, 01:09 PM -
Fuel-Water Separator
By 300Procraft in forum Technical DiscussionReplies: 4Last Post: 09-27-2012, 02:50 PM -
water/fuel separator?
By jjy73 in forum Technical DiscussionReplies: 0Last Post: 09-28-2004, 06:38 AM
