Results 1 to 10 of 10
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    Q about 300R fuel / water separator.
    In the Mercury manual it mentions a "boat mounted" fuel-water separator.
    Is anyone using a Racor type filter? And if yes... a 2-micron or 10-micron?
    Yes, I have one and I also got rid of the primer bulb after I did the initial start up. It fires instantly with the big lift pump. 10 micron filter-
    Dec 2017
    Yes I thought if they mentioned it in the owner's manual without any warnings like for the Opti I should have one. I got a few of those in the barn, gives me a project for the afternoon.
    Feb 2006
    Formerly Central WI/LOTO Currently PHX AZ
    If you have one with the WIF sensor I’d recommend it, as there’s a harness and input for it so you get the warning if water is present.
    A problem is only a problem when viewed as a problem...
    Dec 2017
    Quote Originally Posted by HydroSkreamin View Post
    Yes it says to move the sensor from the on-motor filter to the on-boat filter. And that makes sense. I don't have a bowl with a sensor... yet.
    But with the see-thru bowl I can check water every use and drain if necessary until I get it set up correctly.
    South Africa
    Quote Originally Posted by JPEROG View Post
    Would it not be better to have the primer bulb to flush the water out of the fuel filter?
    Dec 2017
    Quote Originally Posted by Wayne Cammidge View Post
    Not sure what Joe has but mine has a clear bowl on the bottom with a drain cock.
    Jan 2018
    Not a tourist in Forida anymore.
    It’s a restriction in the fuel line and makes the fuel pump work harder.
    Biggest choke point in most fuel systems is the anti siphon pc in the fuel pickup. Filter is nothing compared to that one. Put a vac ga on your fuel line, and check it.
    Quote Originally Posted by TraceF3 View Post
    I have the same-
  1. Mercury Tech: Looks like water in fuel but no water in water separator. Confusing. Any ideas?
    By Steve2ManyBoats in forum Technical Discussion
    Last Post: 07-23-2014, 02:05 PM
  2. Fuel in water separator -- how much is too much?
    By Stoker1 in forum Technical Discussion
    Last Post: 11-04-2013, 01:09 PM
  3. Fuel-Water Separator
    By 300Procraft in forum Technical Discussion
    Last Post: 09-27-2012, 02:50 PM
  4. water/fuel separator?
    By jjy73 in forum Technical Discussion
    Last Post: 09-28-2004, 06:38 AM
