Results 1 to 5 of 5
Thread: DDT on an Opti?
    Jul 2008
    Denton, Md.
    DDT on an Opti?
    Going with a friend to look at an 250 XS Optimax. The engine is not hooked up, the guy sold the boat. Therefore, we cannot hear it run. The guy seems like an honest fellow. Everything he has told him about the boat and engine seems to match his Facebook history. He also appears to take care of his personal belongings by photos on there. It's a 2017 with 100 hrs on it and looks to be in perfect shape. Can a DDT tell you if there are any major problems? Any suggestions on verifying the engine is in good shape? It's currently bolted to a pallet.
    We only go through this circus once...so enjoy the rides!!!
    Western Pennsylvania
    from memory should be able to check faults and history once ecm is powered on?
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
    Jul 2008
    Denton, Md.
    Quote Originally Posted by Euroski View Post
    Ok so does the DDT provide that power or do we need to hook it up to the battery. Sorry I have only seen a DDT used once and the motor was on the boat. We are using a friend's DDT and are going to get a crash course in how to work it here soon. Thanks!
    Aug 2012
    Tenkiller Lake, OK
    You will need 12V DC as well as a way to energize the ECU (key switch and Harness). Not easy W/O these.
    Jul 2008
    Denton, Md.
    Quote Originally Posted by Davidlake View Post
    10-4 David I actually have a new harness I can use. Thank you!
  1. Regular 225 Opti vs 250 Opti XS
    By stingray240cs in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 02-06-2018, 03:28 PM
  2. 3.0 opti
    By xb03fs in forum Technical Discussion
    Last Post: 02-14-2014, 12:07 AM
  3. Dual Repower 225 opti, 225xs or 250xs/opti
    By fishnchips in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 02-18-2008, 08:18 PM
  4. 225 EFi or 225 Opti?
    By wildnphx in forum Technical Discussion
    Last Post: 03-26-2007, 03:22 PM
