Results 1 to 12 of 12
    Mar 2017
    Tampa
    Verado V8 - Blocking off water intake holes
    Center engine on triple yellowfin running low pressure. Apparently it’s quite common to need to block off at least the top 4 holes. Does merc, or anyone else make a plastic or nylon cover or push plugs for this purpose?
    I do not want to tap and screw to plug the holes damaging the paint.
    May 2009
    Ormond Beach, Florida
    Tap and screw or have a shop weld them closed, smooth out the surface and repaint the lower. Those are your only options. 99% of those who do this do the tap and plug method. Is this a 25” or 30” motor?
    Mark
    These are what you need. Tap is effortless due to how close the size is. A drop of loctite and you are good to go. I have all but the bottom two blocked off on my 5.44 HD case which has additional pick ups in the nose and it has all kinds of pressure. McMaster Carr has them in stock.
    Mar 2017
    Tampa
    Quote Originally Posted by mjw930 View Post
    30” Verado V8 300 , I need to take a look at idle and low speed water pressure too, I believe pressure is low across the board. So the issue could be something else. This was 1st run on Brand new engines.
    im getting 2 different size recommendations, someone else recommended 1/4-20 stainless steel 1/2” long for V8 300?
    Mar 2017
    Tampa
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    Mercury makes a kit to close off holes on a 2.5 and maybe the 3.0 but I've never seen one installed on a Verado and you still have to do some drilling. The tap and plug works well. I had a Verado 300 for a few months and all holes were plugged except the bottom 2. If I was going that route I'd use avaition grade thread sealant. I think it will protect better against the interaction between the dissimilar metals.
    On edit- as I think about this the kit might be for scooping more water in to the sides after plugging a few holes.
    They say the mind is the first thing to go...........
    Washington N.C.
    Wrap duct tape around leading edge back to cover the holes first to see if it makes a difference. On our 450's we plugged all "gill holes" , drilled the nose with 4 additional 1/4" holes and a couple 1/2" holes insides the LU. Went from 8 PSI to 30 PSI.
    Mar 2017
    Tampa
    Quote Originally Posted by Mini Max View Post
    Wow, NICE!
    I did determine this past sunday that pressures are equal to the outer engines when the jack plate is all the way down. If I raise more than 1 inch, that's where the center engine starts to drop, but so does performance. So....I need to play with it a bit more to see if it'll be worth it.
    Nov 2019
    Canada
    Merc actually released an updated case with more holes in the nose, they also added some holes internally below the water pump. They say it increases water pressure by up to 10PSI. You could drill these holes and probably get the same results.
    Blake
    www.InjectorService.com
    Call/Text - 204-326-0390
    ...those dang floppy-vane impellers i'll tell ya...
    Mar 2017
    Tampa
    Sooo. When tapping the holes , do you run the tap/threads all the way? Or must you take care to stop, so the screw sets/stops.
    ‘’Also, what’s the best size set screw and tap size to use in the new V8 hD lowers?
  12. #12
    Ft. Lauderdale, Fl
    You say you lose performance when the water pressure drops? Perhaps you need to lower the center motor so it doesn't break loose before the others.....
  1. Water Pressure and Blocking off gearcase holes Questions
    By TwzteD in forum Technical Discussion
    Last Post: 08-20-2018, 02:50 AM
  2. Blocking water pickup holes
    By cheapbeater in forum Technical Discussion
    Last Post: 05-28-2009, 08:04 AM
  3. blocking intake holes
    By dschifan in forum Props, Setup, and Rigging
    Last Post: 05-07-2006, 07:38 PM
  4. blocking water pickup holes
    By alan griffiths in forum Technical Discussion
    Last Post: 09-28-2004, 06:38 PM
  5. plugging water intake holes
    By goodsax in forum Technical Discussion
    Last Post: 04-19-2003, 01:12 PM
