Results 1 to 3 of 3
    Ft. Lauderdale, Fl
    2016 Winnie Ford f450 cameras
    A friend of mine has a 2016 Winnebago with the Ford 450 chassis. The Nav/radio display switches to the side view mirror cam whenever he uses the turn signal. Is there a way to disable it so the display stays on whatever is on rather than going to camera when he uses the turn signal? And at the same time, retain the backup camera?
    Central, PA
    Quote Originally Posted by flabum1017 View Post
    Found this thread unanswered, so hopefully this answer helps you.
    Do some research on Forscan, there is a plug in that goes from your OBD port to your laptop. When you login to Forscan, the feature your looking for will be under the Body Control Module. Change the binary code between the 1's and 0's to turn off or on different features.
    I use this program often on my Super Duty to bypass crap like the TPMS which won't transmit through my e rated off road tires.
    Ft. Lauderdale, Fl
    Thanks..... that looks like it just might do the trick!
  1. 2016 Minnie Winnie travel trailer (trade)
    By ultrafast in forum Non-Marine Items
    Last Post: 07-31-2018, 07:53 AM
  2. Security cameras?
    By delawarerick in forum The Scream And Fly Lounge
    Last Post: 10-08-2014, 01:19 PM
  3. Gopro cameras
    By stv92 in forum General Boating Discussion
    Last Post: 08-14-2014, 08:09 PM
