Results 1 to 15 of 15
01-19-2021, 11:08 PM #1Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,640
- 606
- 920
- 1698
- 7137
- 3 Post(s)
Revelution 4 14 5/8 X 22 "10 min. run time" $600.00
01-20-2021, 01:28 PM #2
My Playcraft loves the Revolution props
01-20-2021, 02:31 PM #3Supporting Member
- Apr 2003
- 6,640
- 606
- 920
- 1698
- 7137
- 3 Post(s)
What length hull?, motor, case, height and setback are you running?
01-20-2021, 03:53 PM #4
Joe the Rev4 is also popular with the offshore fishing boater. I ran them on my Contenders. You might list it over at THT.
01-21-2021, 04:37 PM #5
01-21-2021, 09:53 PM #6Supporting Member
- Apr 2003
- 6,640
- 606
- 920
- 1698
- 7137
- 3 Post(s)
I have run a 21 16" enertia eco at 5700-50 mph. Ran the 20" Rev 4 6100 49.8 mph "couldn't go as high with the motor". I am going to try my sportmaster on it and see just how long it stays hooked up. I have 17 inches of setback and 12 inches of travel in the lift. I am shooting for 54 as my goal so I am not very far off.
https://www.youtube.com/watch?v=H4yFgNRC0oM
01-21-2021, 11:42 PM #7
Joe, I use the Rev 4 on my 22' Manitou SHP, 300XS Sportmaster, 10" setback, I run the 19p and get 54mph...I thought it would be faster, but that's it. Tried a 21 Rev4, and a 21 Mirage Plus. Close to same speeds, but the 19 REV4 lets me raise it higher on the sporty and get excellent acceleration to upper 40's. I wanted to push 60 mph with it, but I just enjoy it now.
Good luck with sale...Rev4 is an excellent prop."The Flying Clamato"
...This ain't no Party, This ain't no Disco, this ain't no foolin around..."Talking Heads - Life During Wartime"
The G-Train has left the station.
01-22-2021, 12:07 AM #8Supporting Member
- Apr 2003
- 6,640
- 606
- 920
- 1698
- 7137
- 3 Post(s)
I have the big case with the pick-up in the front of the housing and side pick-ups above. I have all but the two lowest side pick-ups closed off so i can raise it quite a bit as you can see from the rooster tail that its putting up. I am going to try a sportmaster and see just how far i can bring it up without going into crazy slip numbers. I will let you know where I end up. This 300R has enough grunt down low to run a 25 or 26 and I will just raise the plate to pull rpm and see what I net for speed.
I am actually very happy being able to run 50 and cruise at 45 "people don't like the wind going any faster then that and I can still get to destinations in a reasonable time". Any further messing around is just that "messing around", if I ever hit it big, a twin 450 toon would be a fun addition to the fleet.
01-22-2021, 06:42 AM #9
I have a PowerTech OFS4 23p you are welcome to try. It's also an offshore type prop. Stays hooked up well in rough water.
01-22-2021, 09:27 AM #10Supporting Member
- Apr 2003
- 6,640
- 606
- 920
- 1698
- 7137
- 3 Post(s)
Thanks Trace,
I will be in touch with you on that at some point.
01-22-2021, 09:42 AM #11
Great prop, one of our best sellers in the warmer months. GLWS!
01-22-2021, 10:54 AM #12
It is for sale but I'm just offering it to help him get a baseline. He's helped me out before
01-24-2021, 07:27 AM #135000 RPM
- May 2001
- Conowingo Lake,Md-Summer Astor,Fl.- Winter.
- 225
- 7
01-24-2021, 07:50 AM #145000 RPM
- May 2001
- 225
- 7
Joe- check your PM
Jim
00 Playcraft Powertoon 00/200 Optimax
57 Trojan Sea Queen/57 Johnson 35hp
05 J16 Carolina Skiff 93/50 Johnson
86 Harris Pontoon 73/60 Johnson
01-24-2021, 07:53 AM #15
I had Prop Gods work on one of my Contenders back when I was fishin'. And I've hit him up for tech info several times since then. (Ken). Great guy with lots of knowledge.
Time to best the dead "black max", "black box" horse.
By Quinten in forum Technical DiscussionReplies: 8Last Post: 09-16-2013, 06:24 AM -
Think its time, abolish "car pool lanes?" BIG RANT!
By Robby321 in forum The Scream And Fly LoungeReplies: 4Last Post: 09-30-2012, 03:01 PM -
To start OMC V8 for first time. "Wiring" information needed.
By Smoking Joe in forum Technical DiscussionReplies: 17Last Post: 03-27-2012, 03:03 PM -
Wanted, thread titled: Merc Tech, attempting to time the "tower of power"
By gw1250 in forum Technical DiscussionReplies: 2Last Post: 07-13-2010, 03:01 PM -
Thank You one more time for those that donated and helped with "Balz To The Wall"
By Balzy in forum General Boating DiscussionReplies: 6Last Post: 09-25-2002, 02:24 PM
