Results 1 to 2 of 2
    Mar 2002
    Pensacola, Fl.
    280 Wiring question?
    I'm trying to wire up the relay for a weldon fuel pump. The wiring was already in place, installing a different motor and not sure where these wires go. I didn't remove the old motor which was a mercury drag.
    Not sure what Black wire and red with blue stripe are for? Not sure what the brown wire with white stripe is for? I believe that the two wires with the yellow tape should connect together. The two wires in the last picture are going to the relay.
    Thank you in advance!!
    Stoney
    Attached Thumbnails Attached Thumbnails IMG_0982.jpg   IMG_0981.jpg   IMG_0980.jpg
    Jan 2020
    Pinole, Ca
    Brown/white is trim sender.
    That black and the red/purple is keyed power, so that can be used to power a fuel pump, external computer or gauge.
    1990 Collins Mirage - 15" 260
    25 hp Merc with dry side pipe
  1. JL Amp Wiring Question
    By hog wild in forum Electronics, Audio Systems, and Wiring
    Last Post: 08-29-2015, 09:19 PM
  2. OMC Tech: wiring question
    By slowmover in forum Technical Discussion
    Last Post: 05-09-2009, 06:43 AM
  3. Mercury Tech: 225 Pro Max ECU Wiring Question
    By HeadHunter in forum Technical Discussion
    Last Post: 02-28-2009, 08:17 AM
  4. Mercury Tech: 260 ECU Wiring Question
    By RikkiRocket in forum Technical Discussion
    Last Post: 09-21-2008, 03:12 PM
  5. wiring question
    By CharlieB in forum Technical Discussion
    Last Post: 03-27-2007, 05:16 AM
