Results 1 to 4 of 4
01-18-2021, 06:27 AM #1
Anybody ever use different coils on a 2.5 EFI
Reason I'm asking is I'd like to put new coils on the motor and thought I ask before I spend the coin for exact replacements. Figure maybe somebody has tried something different like this before. Wondered if the square single cylinder Opti coils would work (my 2 wire, Opti 3 wire) ?
Thanks
01-18-2021, 07:00 AM #25000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
I just had a could take down a driver and had to repair the ECU on a 2005 280 and I believe there was an aftermarket coil that saves about 20 bucks each . This conversation on aftermarket was at a parts counter and it was a quick conversation , I did not get the vendors name - all i was made aware of is the small amount differance . Hope this helps
Liberator*21 liked this post
01-25-2021, 04:19 PM #35000 RPM
- Jun 2014
- United States
- 153
- 7
- 30
- 42
Eric Kaiser has used the newer design coils on a 2.5, but he was probably using Motec or some other aftermarket ignition.
01-26-2021, 06:42 AM #4
Motec actually sells the mercury coil as they seem to be the best cdi coil
which coils have more output-optimax or gm ls series coils?
By mrcrsr in forum Technical DiscussionReplies: 189Last Post: 08-03-2011, 08:22 AM
